Using 2 different gauge springs for edge zero ii - Jemsite
post #1 of 5 (permalink) Old 01-16-2019, 05:37 AM Thread Starter
Hi guys, just wondering if there's anything wrong with using both gauges of spring that come with Edge zero ii equipped guitars? My RGD has a 7 string edge zero ii tremolo and I'm tuned to e flat (7th is b flat) so... B flat standard I guess? Using 09-46 with a 54 on the bottom. It seems like there's not enough tension when using the stock springs, and slightly too much when using the power springs. I don't really want to change string gauges, so could I use 1 power spring and 1 regular spring? Theoretically, that would completely solve my problem. I'm fairly experienced with trem systems, and I feel the only options I have are to use uneven spring gauges or change string gauge. Thanks in advance.
Reaper121088 is offline
post #2 of 5 (permalink) Old 01-16-2019, 07:00 AM
Re: Using 2 different gauge springs for edge zero ii
how many springs do you have? if the number is even, use them symmetrically left and right. if not again retain symmetry.
xinap is offline
post #3 of 5 (permalink) Old 01-16-2019, 07:33 AM
Hmm, I have an Edge Zero 7 with standard springs and tuned flat like you with 9-46 and a 56-string.
Works perfectly for me. The tension knob is pretty much centered.
OTOH I don't see a problem with mixing springs. Give it a try.
TJ777 is offline
post #4 of 5 (permalink) Old 01-16-2019, 08:54 AM
There is no technical reason why you can't mix spring rates to achieve a balanced system, the system sees only total spring tension which is simply the sum of all the springs installed.
sepulchrave is offline
post #5 of 5 (permalink) Old 01-23-2019, 07:57 PM
I've worked with a ton of floating ibz trems. If you use mixed springs make sure to tighten and tune the respective side of strings to keep the bridge flat and adjust the studs accordingly.
mbagchi is offline
Edge Zero II With ZPS3 String Gauge Change BR0CKO5 All Other Guitars (including Prestige) 2 06-21-2018 11:45 PM
Can Edge Zero II fit in Edge Zero cavity? bancika All Other Guitars (including Prestige) 2 05-11-2018 10:57 AM
Replacing Edge Zero ii with Edge Zero rmelancon1432 Tech: Setup, Repairs and Mods 25 05-02-2016 07:30 AM
Replacing edge zero with edge zero II? Ansio Tech: Setup, Repairs and Mods 14 11-19-2015 01:08 AM
Using different gauge strings on the same guitar ??? IbanezFreak777 Tech: Setup, Repairs and Mods 6 07-24-2010 03:28 PM
