Using pedals with a rack unit - getting confused - Jemsite
post #1 of 11 (permalink) Old 01-29-2012, 12:54 AM Thread Starter
Hey guys,
I decided to introduce pedals into my chain after having just a simple multi effects unit through my amp's fx loop. I'm having trouble setting up a proper chain. The way I have it now, it seems my analog delay seems to be breaking up a bit, as it is in front of the amp. Also, it seems the first delay feedback is louder than the actual signal.
Anyway, here is what my chain looks like now
Guitar > Tuner > Wah > Flange > Chorus > Analog delay > Input of amp > Amp Fx loop send to Input of my multi effects > Out of multi effects into loop station > Out of loop station to return of fx loop.
Would I get better, more clear results if I changed this up?
Example:
Guitar > Tuner > Wah > Input of amp > Fx loop send of amp to all the other pedals in order (i.e Flange>Chorus>Analog Delay>Multi effects>Looper>Fx loop return
I also want to continue to take advantage of my multi effects' noise reduction system etc.
I'm getting confused lol
Tannen is offline
post #2 of 11 (permalink) Old 01-29-2012, 01:08 AM
Re: Using pedals with a rack unit - getting confused
Time based effects(chorus,flange,delay etc) MUST be post amp,in the effects loop.
Thats your problaem,you are delaying your guitar and signal before it's gone through the pre-amp stage where you are generating your tone,every delay repeat is also getting gain from running through the pre-amp.
Put it in the amps effect loop,then you will be adding a pure delayed effect to your finished tone.
The pedals you put in front would be drive pedals,wah etc....pedals that 'push' and or distort.
corey j grieve is offline
post #3 of 11 (permalink) Old 01-29-2012, 01:28 AM
In mind with Corey's advice
You > Guitar > Tuner > MultiFX > Wah (interchangable?) > Amp In > Effects Loop out > Flange > Chorus > Delay> Looper > Effects Loop Return
BlanK is offline
post #4 of 11 (permalink) Old 01-29-2012, 10:04 AM Thread Starter
Awesome. I'll change this today. However, would those pedals (i.e. flange, chorus, delay) go BEFORE or after my multi effects unit? Or is that interchangeable?
Tannen is offline
post #5 of 11 (permalink) Old 01-29-2012, 10:49 AM
What are you using it for? Generally, you would want delays and reverbs to make up the end of your chain. So, if you using the multi effect for reverb, then I'd put it last. If you're not using it for delay or reverb, I'd put it anywhere in front of the delay pedal.
You can get some pretty cool sounds, though, putting effects in unconventional (not sure that's the word I'm looking for) orders. Test your chorus pedal right before and after your distortion pedal. I think it sounds pretty damn cool before.
xXLinkageXx is offline
post #6 of 11 (permalink) Old 01-29-2012, 11:42 AM Thread Starter
I use my multi effects for digital delays, reverbs, and especially the noise reduction system in it. And sometimes EQ and phaser. I might try my chorus in the loop but in front of the effects and delay. My flange pedal I had to put in front of my amp because it's the Paul Gilbert airplane flanger. If you try and put it in Take Off mode (where it completely takes over your signal) and use it in the fx loop, I probably would have blown a speaker. That one definately works best in front of the amp. Nice point about trying chorus before/after distortion pedal but I just the my amp's overdrive - plenty of gain with my Peavey 6505+.
So most likely put multi effects at the end of my chain? (well, before the looper as that needs to be last in the chain to record/loop properly).
Tannen is offline
post #7 of 11 (permalink) Old 01-29-2012, 07:59 PM
or if your multiFX has it's own loop-out/return what you can do is
You > Guitar > Tuner > MultiFX (Loop out) > Wah (interchangable?) > Amp In > Effects Loop out > MultiFX (Loop return) > MultiFX (Live Out) > Flange > Chorus > Delay> Looper > Effects Loop Return
Man... that's a mouth-full...
So that means, the distortions pedals and distortion patches from the MultiFX is going into the preamp. Preamp comes back out going into the FX loop return on the Multi. Then the Multi goes into the flange and phase and looper. Looper goes into power amp.
BlanK is offline
post #8 of 11 (permalink) Old 01-29-2012, 10:21 PM Thread Starter
Cool, unfortunately mine does not (only in/out). Now I need to test out if my pedals before my muli effects will get affected somehow being that they are before the noise reducer in the unit.
Tannen is offline
post #9 of 11 (permalink) Old 01-29-2012, 11:30 PM
Reviews: 4
in my book, wah comes before the MFX. just me, though.
fwd0120 is offline
post #10 of 11 (permalink) Old 01-30-2012, 12:21 AM
Where in canada are you tannen?
BlanK is offline
post #11 of 11 (permalink) Old 01-30-2012, 08:01 AM Thread Starter
Me too. I'm just trying to tinker with having my stomboxes (modulation/delay) before or after mfx.
Northern Ontario
Tannen is offline
Help with signal chain - using rack unit AND pedals Tannen Tech: Setup, Repairs and Mods 4 01-07-2012 06:29 PM
rack unit - what do you have masterplan Gear, Equipment, Recording & Off Topic 19 02-20-2002 04:09 PM
Something is up in my rack unit? - help, I can't use my effe MorbidAngel Gear, Equipment, Recording & Off Topic 10 09-19-2001 07:34 PM
