UV777 tremolo's interchangeable - Jemsite
post #1 of 7 (permalink) Old 05-29-2018, 09:26 AM Thread Starter
Hi all,
Want to know if the Edge Pro 7 tremolo off the UV777 models produced from 2003 to 2009
can be swapped for the Lo Pro Edge 7 tremolo off the earlier and later UV777 models (1998 - 2002 and 2010 - 2012) ?
Basically, are all UV777 bodies from 1998 up to 2012 routed the same ?
Have tried searching this forum but didn't come up with the answer, but i'm confident there's enough knowledge on here to answer this question
apex is offline
post #2 of 7 (permalink) Old 05-29-2018, 10:11 AM
Re: UV777 tremolo's interchangeable
Why would you want to swap, just retrofit the locking posts and the performance is just as good.
sepulchrave is offline
post #3 of 7 (permalink) Old 05-29-2018, 10:50 AM Thread Starter
Personal preference ... i like the Lo Pro, used to it from playing a K7.
I dont get what you say about retrofitting locking posts ??
apex is offline
post #4 of 7 (permalink) Old 05-29-2018, 11:31 AM
site founder 0% owner
jemsite's Avatar
I would expect them NOT to fit based on the body route but i have not personally tried or measured. Think of the 6&7 trems & routings to be the same just the 7 is wider.
jemsite is offline
post #5 of 7 (permalink) Old 05-29-2018, 12:01 PM
If you square off the front corners of the rout beside the studs a Lo Pro will fit, otherwise they rounded off those corners for the Edge Pro guitars, 6 and 7.
Rich is offline
post #6 of 7 (permalink) Old 05-29-2018, 01:26 PM Thread Starter
Thanks Rich. Again
apex is offline
post #7 of 7 (permalink) Old 05-30-2018, 06:38 AM
Original Edge and Edge Lo Pro trems have pivot bolts with locking screws down the middle of them so that once the height of the post is set it can be locked in place so that it can't move.
From a functional and technical perspective that's the only real advantage over the Edge Pro.
Are the ZR and Edge Zero interchangeable? Blacksabba Tech: Setup, Repairs and Mods 0 05-07-2011 09:25 AM
Interchangeable pickguards rg550 rg2550 Foulacy Tech: Setup, Repairs and Mods 1 10-14-2008 04:50 PM
Are all RG3120 necks interchangeable? TheJazzTerminator All Other Guitars (including Prestige) 2 12-02-2007 03:46 PM
Interchangeable Bridges for the RG? Fang All Other Guitars (including Prestige) 8 09-30-2006 05:18 AM
interchangeable necks? - rg series craig Tech: Setup, Repairs and Mods 3 07-20-2001 02:05 AM
