UV777BK trem problem - I think it is a problem (shrug) - Jemsite
post #1 of 6 (permalink) Old 09-20-2001, 10:59 PM Thread Starter
Well..
I have pics on my comp to show you guys how it is set up, but no way to get them to you.
when I dip drop my bar all the way down to the pickguard, the strings don't get "floppy" and I when I pull up it doesn't seem like it is going high enough....
...On a jem it works fine...
I was thinking... can I bend my bar at a different angle?
PLUS!!!....the bar feels really stiff, in terms of movement.
Strung with .10-.56's
Scoff X is offline
post #2 of 6 (permalink) Old 09-20-2001, 11:04 PM
Man I type this alot, sounds like you need a neck shim.
Rich is offline
post #3 of 6 (permalink) Old 09-21-2001, 12:05 AM Thread Starter
which is?
Sorry not up to tech side...just playing =)
Scoff X is offline
post #4 of 6 (permalink) Old 09-21-2001, 12:54 AM
a neck shim fit under the neck (in the neck joint - wheere the neck meets the body) to raise it (the neck slightly
one less than none is offline
post #5 of 6 (permalink) Old 09-21-2001, 01:52 AM Thread Starter
hmm.. how would that affect how far i can drop/pull up on the bar?
Scoff X is offline
post #6 of 6 (permalink) Old 09-21-2001, 01:59 AM
Increase the neck angle you'll have to raise the trem to compensate. Raising the trem give you greater range down and up.
Rich is offline
neck angle , neck joint , neck shim
Edge pro angle problem (uv777bk) JN777 Ibanez JEM, UV, JS & Other Signature Models 1 01-11-2005 08:07 PM
UV777BK Intonation Problem Vegas_Blues Tech: Setup, Repairs and Mods 2 11-20-2004 04:44 PM
My UV777BK problem :) Wadstein Ibanez JEM, UV, JS & Other Signature Models 10 05-19-2003 12:38 PM
UV777BK muddy sound problem felipennn Ibanez JEM, UV, JS & Other Signature Models 3 03-05-2003 02:39 PM
Trem height and action problem. - Lowest possible trem heigh Theater of Dreams Tech: Setup, Repairs and Mods 2 04-29-2002 03:45 AM
