Video: Treble bleed volume circuit with and without a resistor - Jemsite
post #1 of 1 (permalink) Old 07-31-2015, 01:19 PM Thread Starter
There doesn't seem to be a way to embed this, but:
http://www.youtube.com/watch?v=mGXdKqhTW2c
I threw a new SSS pickguard on my Strat recently (I'd had it SSH for years), and in doing so tried a couple different treble bleed approaches - I didn't do any video of the "50's wiring" approach, but I did a before/after when I decided to remove the resistor wired in parallel with the capacator (which is the standard "treble bleed" mod).
I was surprised to find how much I preferred this mod without the resistor, but I probably shouldn't be - I guess a cap, no resistor, is standard on most Ibanez guitars, and furthermore when I went back to check is how I'd had my strat wired up in the past. A lot of people find the capacator alone too pronounced and add a resistor in parallel to lessen the effect somewhat; I'm not one of them. I ride my volume knob a fair amount while playing, and use it mostly to control the perceived saturation on a moderately overdriven amp (here, in the first two clips, a Rectifier Roadster in Ch. 3 Vintage, my usual lead setting - the final is Ch4 for a heavy high gain sound). With the resistor, you didn't preserve the high end clarity quite as well as you rolled the volume back - there's an appealing vintage-y softness to the highs, and it probably would be ideal for a clean player or a guy looking to use his volume knob to sit back a bit while playing rhythm, but for lead work it didn't clean up as nicely and changed the tone more than I wanted. Without a resistor, there's a TON more sparkle left in the signal than with.
I think the third clip, around 1:40, is hilarious; it's a heavy Rectifier crunch, yet with the volume back it's a clean tone that wouldn't be out of place on a Black Crowes album.
Drew is offline
capacitor , strat , treble bleed , volume , wiring
Polystyrene Cap in Treble Bleed Circuit TremoJem Ibanez JEM, UV, JS & Other Signature Models 4 11-02-2012 09:30 AM
Jem7VW Treble Bleed TremoJem Ibanez JEM, UV, JS & Other Signature Models 6 10-02-2012 12:11 AM
I Snipped the Treble Bleed Cap and... NT02 Pickups & wiring 13 07-16-2012 12:25 PM
need perfect sound out of evo's. pots, bleed circuit etc? fireheart82 Ibanez JEM, UV, JS & Other Signature Models 17 04-07-2011 05:01 AM
treble bleed cap and 300 pf thing? help? Cam-Vai Pickups & wiring 3 03-25-2009 05:59 PM
