vintage tremolo help!!!! - Jemsite
post #1 of 12 (permalink) Old 10-31-2011, 05:15 AM Thread Starter
Smile vintage tremolo help!!!!
is it wise to keep a vintage tremolo floating by loosening the tension of the spring , like the strat vintage tremolos or prs ones ??? or is it best to keep it in a normal position as in it will hit the surface of the guitar every time i use it ...?
bonsuer is offline
post #2 of 12 (permalink) Old 11-01-2011, 11:41 AM
Reviews: 98
Re: vintage tremolo help!!!!
Vintage Strat trems are not floating trems.
AlaskaBat is offline
post #3 of 12 (permalink) Old 11-01-2011, 12:12 PM
You can set it for a light float. Jeff Beck has been using his this way for years to good effect. I think Carl Verheyen uses this setup on his Strats too.
Mark_McQ is offline
post #4 of 12 (permalink) Old 11-02-2011, 09:55 AM
Reviews: 6
Actually, the classic Strat setup has the bridge sitting off the body -- I can't remember the exact amount at the moment, but it's along the lines of 1/8th of an inch. As the trem easily goes out of tune with use, I find it useful to leave the bar off the guitar and deck mine.
Philboski is offline
post #5 of 12 (permalink) Old 11-08-2011, 02:31 AM
Its standard to float a little. I don't think a lot of people know that or care.
I have one guy that plays with 8s on his strat and wants the trem to float a little. He plays surf music. Took a spring out and backed the other two out and floated nicely. You can't pull up a ton on a strat, but maybe a half step. Enough to get some cool vibrato going.
jasondmckay is offline
post #6 of 12 (permalink) Old 11-11-2011, 07:24 AM Thread Starter
i am having the G string tuning problem if i float the bridge!!!
so planned on keeping it flat on the surface !!!
bonsuer is offline
post #7 of 12 (permalink) Old 11-11-2011, 07:32 AM
jb4674's Avatar
Reviews: 18
http://youtu.be/Iy-F7iSIopA
Jimmy
jb4674 is offline
post #8 of 12 (permalink) Old 11-13-2011, 04:33 AM
I thought Jeff played a 2-point trem
BlanK is offline
post #9 of 12 (permalink) Old 11-13-2011, 06:11 AM
Reviews: 98
They rock, not float. If it's screwed to the body by 6 screws--it doesn't float. Ha ha ha ha
post #10 of 12 (permalink) Old 11-13-2011, 10:19 AM
Fender's own spec is 1/8".
http://www.fender.com/support/articl...er-setup-guide
I set my Strats up like this, because I like to be able to add a little lap steel style vibrato to chords, which was actually the original intent of the tremolo. Personally, I think it helps the guitar return to tune better with MILD vibrato use than having the trem be flat against the body. Until I break a string LOL. Having said that, a LOT of people prefer their trems to be flat against the body, so it's not "wrong" to set them up that way.
Basically it comes down to how you're going to use it, and what your own personal preferences are.
dcord is offline
post #11 of 12 (permalink) Old 11-14-2011, 11:44 AM
Reviews: 6
^ Agreed. I used to leave mine to "float" because I loved the percussive attack I got from it, and that lovely "Stratty" sound I got, even with a humbucker. Now I have it decked, and it's working for me. Easy enough to change back, I guess.
post #12 of 12 (permalink) Old 03-05-2012, 07:46 PM
I deck my vintage 6 screw as well as 2 post non-locking trems.
Yes they are thus dive-only, but that's how I like my trems.
With a 6 point, I loosen the inner 4 about .75mm and use the outer 2 screws as if they were the 2 posts- very common practice, and those I loosen .5mm.
Also I use 4 springs and adjust the claw so that the plate is flush against the body (decked) but also so that a dive can be performed without too much effort...
Stradovarious is offline
prs , strat , tremolo , vintage
Vintage Morley PWB, Vintage MXR Flanger, MXR Phase 90, Carl Martin Chorus Sevenstringer Classified Ads: Guitars and Gear 1 02-27-2012 02:29 PM
Replacing vintage tremolo Anticross Tech: Setup, Repairs and Mods 4 09-19-2011 10:14 AM
Is the Edge-Zero II Tremolo a good tremolo system dburn42 All Other Guitars (including Prestige) 6 05-30-2011 10:12 AM
Check out my New Vintage Ibanez (heh New Vintage) rich2k4 All Other Guitars (including Prestige) 5 02-20-2006 02:13 AM
Vintage!! - For vintage freaks only!! Pedalboards, amps and Skully Gear, Equipment, Recording & Off Topic 17 01-12-2002 11:55 AM
