Volume knob gets all loose - Jemsite
post #1 of 9 (permalink) Old 01-16-2004, 12:45 PM Thread Starter
Anyone have suggestions on how to keep the nut from loosening so much? I don't want to tighten it up for fear of cracking the pickguard.
xaoscontrol is offline
post #2 of 9 (permalink) Old 01-16-2004, 11:48 PM
Just tighten it, simple as that. Just enough so that it's set, don't put 50 ft/lbs on it, just torque it down so it holds.
Pickguards are pretty damned tough, you would be amazed at how much it takes to crack one with a simple nut and washer. :-)
Mic
MicJustMic is offline
post #3 of 9 (permalink) Old 01-16-2004, 11:51 PM
Unless it's a mirror guard, they will crack fairly easy
Rich is offline
post #4 of 9 (permalink) Old 01-17-2004, 12:00 AM
Good point Rich . . . so that leads to the question . . .
IS it a mirror guard? :P
If not, get out that open end wrench and go for it. :-D
Mic
post #5 of 9 (permalink) Old 01-17-2004, 12:05 AM
If you have problems with it continually coming loose, take the pot off and put a lock washer on the shaft of the pot and put it back on the pickguard (with the lock washer on the inside).
darren wilson is offline
post #6 of 9 (permalink) Old 01-17-2004, 11:22 PM Thread Starter
Guess I should have mentioned that...
Tis a UV777....mirror guard.
Even still, I've heard horror stories on this very board about people messing up the pickguard.
Not to mention I've had a dream or two where I discovered that my UV had a big honkin' ding in the binding...so I cried.....call it being paranoid.
Guess I really wanted to be assured that I can tighten it down reasonably without cracking something.
Thanks though.
post #7 of 9 (permalink) Old 01-17-2004, 11:37 PM
"Reasonably" being the key word here
Rich is offline
post #8 of 9 (permalink) Old 01-17-2004, 11:41 PM
Fry
how about some lock tight? seems like it would work.
Fry is offline
post #9 of 9 (permalink) Old 01-19-2004, 06:14 PM
Or just a tiny drop of nailpolish to seal after you´ve tightened it up?
JEM10th is offline
Wire between toggle and volume knob on JEM 7V has broken off the knob side Hiketsu Tech: Setup, Repairs and Mods 2 11-17-2010 04:22 AM
Loose Volume Knob!!! Help!!! SpaceMusic All Other Guitars (including Prestige) 6 07-08-2010 12:42 AM
my tone knob is a volume knob... Homebake Pickups & wiring 12 06-27-2009 02:15 PM
Loose volume knob Clydefrog Tech: Setup, Repairs and Mods 1 03-27-2006 11:58 PM
Volume knob getting loose!! Help davester1234 Tech: Setup, Repairs and Mods 1 05-07-2002 04:00 PM
