Volume Knob Noise - how do I get rid of it? - Jemsite
post #1 of 7 (permalink) Old 01-28-2002, 06:49 PM Thread Starter
Greetings,
So I'm playing my RG today and I roll down the volume to get a more subtle crunch going on.. and all I hear is *ppppfffffhhhhh* - static as I move my volume knob around!
What's causing this? Do my pots need cleaning? What do I need to do to eliminate this...
I have a good idea about how to go about fixing this but I want some other opinions first...
Thanks in advance!
Raven777 is offline
post #2 of 7 (permalink) Old 01-28-2002, 07:04 PM
Volume Knob Noise
Clean the pots man.
Two hands31 is offline
post #3 of 7 (permalink) Old 01-28-2002, 08:12 PM
Volume Knob Noise
get a can of Deoxit D5. it is the best stuff out there...
www.caig.com
vwall is offline
post #4 of 7 (permalink) Old 01-30-2002, 03:41 PM
Volume Knob Noise
Open the cover plate or remove the pickguard and squirt some contact cleaner in the slot of the potentiometer and turn the knob back and forth, do your 5 way switch as well.
Make sure you find a cleaner that does NOT melt plastic.
Bamm
bammbamm is offline
post #5 of 7 (permalink) Old 02-03-2002, 11:45 AM
Volume Knob Noise
You can use a isopropilic alcohool. Don't have water.
LGMT is offline
post #6 of 7 (permalink) Old 02-05-2002, 02:47 PM
Volume Knob Noise
Isopropyl alcohol usually IS mixed with 30% water unless you can get a 100% solution.
Use spray contact cleaner, it is MUCH easier to get it where you need it versus a non compressed liquid.
Bamm
bammbamm is offline
post #7 of 7 (permalink) Old 02-07-2002, 06:47 AM
Volume Knob Noise
Sure Bammm, but i have seen here some at 1 Mol.
LGMT is offline
Wire between toggle and volume knob on JEM 7V has broken off the knob side Hiketsu Tech: Setup, Repairs and Mods 2 11-17-2010 04:22 AM
my tone knob is a volume knob... Homebake Pickups & wiring 12 06-27-2009 02:15 PM
less volume when knob on 10. 70Seven Tech: Setup, Repairs and Mods 5 08-06-2008 05:25 AM
Pb with volume knob Attwad Tech: Setup, Repairs and Mods 4 02-27-2004 01:38 PM
Volume knob PRSKILLER Ibanez JEM, UV, JS & Other Signature Models 36 12-28-2003 09:01 PM
