wants to reduce the brightness of ash body - Jemsite
post #1 of 10 (permalink) Old 02-07-2012, 09:24 AM Thread Starter
Guys, needs some advise.
I want to reduce some brightness / treble on the ash-body guitar that I have.
I love this guitar but for me the treble just killing my appetite.
the guitar is RG with see-through finish, maple + rosewood board, nothing special.
I know some options to be taken/ will be taken to reduce the treble :
1. changing the pickups with darker one.
2. put heavier gauge strings, right now I'm using 09, but considering to put 10s.
my question is :
if i remove the finish ( the paint and clear coat) on the body, and let the body natural with no finish or maybe satin oil finish only, will it help to reduce the brightness? or just make it worse?
the reason why I'm considering to remove the finish, because just playing this guitar unplugged , I can hear it's very bright already.
thanks in advanced !!
psychoshredder is offline
post #2 of 10 (permalink) Old 02-07-2012, 09:39 AM
Reviews: 6
Re: wants to reduce the brightness of ash body
to me it won't change anything, I've an ash body Kawai Aquarius in natural finish, the guitar is bright.
The brightness is due to the wood, not the finish.
I recommand you to change the pickups
Switching from 009 to 010 strings gauge will not affect enough the brightness.
Check for pickups with a lot of mids and a lot of bass
satch_jr is offline
post #3 of 10 (permalink) Old 02-07-2012, 10:01 AM
Changing the strings can help a lot, too!!
Certainly a warmer tone can be achieved by using Elixir Nano Web strings.
And reducing the tone control down to max 1 - 2.
My RG 350 is pretty bright as well (stock pickups) but with the Nanos and tone at 2 it sounds nicely dirty/rocky.
Even easier, in case you don't have to change guitars between songs: adjust your amp setting
Jemanized is offline
post #4 of 10 (permalink) Old 02-07-2012, 11:14 AM
Reviews: 64
Every gear we plug our guitars into have an eq.
And even if didn't have, for the love of god buy a 60 dollars eq pedal.
Or what?
Keep changing woods, pickups and strings till got the right equalization?!
Gear(pickups, strings, amp/effects) affects 99% of a solid guitar tone so wood have just a little participation and you can change that participation =
BUY A 60 DOLLARS EQ PEDAL!
6fingers is offline
post #5 of 10 (permalink) Old 02-07-2012, 01:46 PM
Super Moderator
there are loads of different ways of doing this depending on a) how much you want to spend and b) how far you're prepared to go.
the easiest way is to turn down the tone control on the guitar, or the treble control on the amp. If you're looking for something a little more fun, replacing a maple neck with a specially made solid rosewood neck will warm things up a bit, but cost a small fortune.
The most cost effective answers that are still "fun" would be to treat yourself to a new set of pickups which will allow you to tailor the tone in each position on the guitar, or like 6fingers said, invest in an equalizer pedal which will give you a different tone curve at teh touch of a footswitch
jono is offline
post #6 of 10 (permalink) Old 02-07-2012, 03:08 PM
I am thinking just screwing a big block of wood to it would help.
Or maybe a G clamp like the fender fatfinger.
LostInRockFormations is offline
post #7 of 10 (permalink) Old 02-07-2012, 08:15 PM Thread Starter
I think playing with the eq won't help much...
the real problem is coming out from the guitar, let me explain :
the way I'm playing result somewhat buzz on some strings, even on an open string, is not a dead buzz, it's more like 'twang'.
adjusting the neck relief? done
adjusting the string action? done
so I'm comparing side by side : same guitar ( RGs), same set up, same string gauge.
one is ash , one is basswood.
acoustically ( unplugged), i can hear the ash is brighter.
plug it in to an amp : the twang on the ash get worse, like I said..even on an open string it twangs.. damn it, i just can't stand it.
I read somewhere that clear coat on guitars effected to the brightness also, that's why I asked, in Ibanez... does it have something to do with the tone?
If I remove the paint, will it be less bright or more bright?
post #8 of 10 (permalink) Old 02-19-2012, 02:35 AM
Try a 250k volume pot instead of the 500k that I assume you have.
Petie is offline
post #9 of 10 (permalink) Old 02-19-2012, 03:42 AM
RGTFanatic's Avatar
First sensible answer yet.......
Switch both the tone and vol. to 250k pots. You can also use a higher value cap on the tone control, but that will only make a difference once you roll the pot back a bit.
It would also be wise to double check all of your wiring. A bad solder connection can leave a guitar sounding very thin.
Removing the clear will do nothing, other than making your guitar less shiny.
RGTFanatic is offline
post #10 of 10 (permalink) Old 02-19-2012, 04:12 AM
Reviews: 120
A 250K is exactly what I was going to say too. That or a Tone Zone if you want to change pickups.
LonePhantom is offline
ash , bright guitar
Truss rod to reduce buzz? paison90 Tech: Setup, Repairs and Mods 3 05-17-2011 01:02 AM
Will using a XLR (I think) for my rack EQ reduce noise? IBNZ_RG Gear, Equipment, Recording & Off Topic 8 06-30-2010 01:50 PM
Brightness Devon8822 Ibanez JEM, UV, JS & Other Signature Models 10 11-11-2008 07:03 PM
Need help: where's the brightness? paramex Tech: Setup, Repairs and Mods 2 09-21-2006 03:00 AM
removing tubes to reduce power - anybody do it? shred4Him Gear, Equipment, Recording & Off Topic 10 11-26-2001 10:47 AM
