Weird Guitar Problem - Jemsite
post #1 of 11 (permalink) Old 09-30-2011, 02:11 PM Thread Starter
A few years ago I had a Vigier Excalibur and it had a problem whereby the A note would sort of buzz on the 7th fret D string.
All the other notes on the 7th fret were OK, just that A note. The buzz wasn't audible through the amp, although if you really whacked the string it was but I can't imagine anyone belting the strings in such a fashion.
Now on my Ibanez I have this problem on the 7th fret, D string A note! I was using Ernie Ball strings but now I'm using D'Addario. It's not coming through the amp but I'm just curious as to why this is happening and if anyone has ever heard of this before?
My set up is as follows:
Action = 2mm bass and treble from bottom of string to top of 12th fret.
Relief .007" at 7th fret
I've been using this set up for years and it's only on my Vigier and Ibanez guitars that I've had this mysterious 7th fret D string problem. If I straighten the neck the problem gets a lot worse and it becomes audible through the amp. All other notes on the 7th fret are OK. The intonation on the 7th fret D string is perfect. I tune to A standard 440. My frets are all level as I have checked them myself with a fret rocker tool.
Any ideas?
aliendough is offline
post #2 of 11 (permalink) Old 10-01-2011, 03:30 AM
Re: Weird Guitar Problem
7 ,Seven days in a week,seven tones of the scale,the beast with seven heads. A ,the first letter,the beginning .I think the buzz has strong meaning and the guitar will give you magic. Don’t mess with it, you are lucky to have that buzz.
moonlight is offline
post #3 of 11 (permalink) Old 10-01-2011, 03:44 AM
maybe something's gotten loose, like the small adjustment screws on a tele saddle
BlanK is offline
post #4 of 11 (permalink) Old 10-01-2011, 08:22 AM Thread Starter
I just changed strings yesterday and everything is tight.
post #5 of 11 (permalink) Old 10-07-2011, 12:32 PM
The first thing anyone would say ofcourse would be that your fret is probably loose, but since you said that you checked them all and they are fine that is clearly not the answer. If it was me I would adjust my truss rod to make sure the neck is straight, then I would adjust my action accordingly aswell as be sure that the buzz is not just being caused by loose tuning keys that are being shaken just by the frequincy of the a note (which has happened to me lol) but other than that I cant say. check it out and let me know and ill give more suggestions. Good Luck!
- Alex
FunkyDice is offline
post #6 of 11 (permalink) Old 10-18-2011, 12:36 PM
Is it a fret buzz? Or could it be some sort of sympathetic resonation of some hardware on the guitar?
shotgunn is offline
post #7 of 11 (permalink) Old 10-18-2011, 08:39 PM
If it's not fret buzz, it's something resonating, as shotgunn said.
Check the saddle for burrs, that would be my first suspect. Usually a burr on the saddle will cause all notes on a string to buzz, but sometimes not... things can get a little weird on these things...
@FunkyDice: I see time and time again people telling someone to "make sure the neck is straight", if you mean it literally, 'straight', a guitar neck actually should have a slight, or sometimes not so slight, bow forward. Usually when the neck is straight, you're asking for problems... like fret buzz and playability issues.
If you just meant in general, 'make sure your neck isn't bowed too far forward or back', then I apologize for my assumption.
MicJustMic is offline
post #8 of 11 (permalink) Old 11-06-2011, 06:41 PM
Could be low action, the string's vibrating path, mixed with that string gauge hitting the apex/curve of the neck.
All good/low actions have a little buzz when not plugged in. If it bothers you, back off the truss rod a little, or stop listening for it. :-)
Have to remember, it's only a guitar.
jasondmckay is offline
post #9 of 11 (permalink) Old 11-11-2011, 01:18 PM
Every guitar is different and everything - every part - resonates in its own ways. Perhaps that wasn't too helpful though...
JonatanOTG is offline
post #10 of 11 (permalink) Old 11-11-2011, 02:05 PM
Reviews: 64
Originally Posted by moonlight View Post
7 ,Seven days in a week,seven tones of the scale,the beast with seven heads. A ,the first letter,the beginning .I think the buzz has strong meaning and the guitar will give you magic. Donít mess with it, you are lucky to have that buzz.
6fingers is offline
post #11 of 11 (permalink) Old 11-11-2011, 03:34 PM
Reviews: 4
Ninja'd by 6f....
Really, if it isn't that apparent, those kinda flukes seem to show up all the time. Good luck, hope you can get it resolved.
fwd0120 is offline
Weird MP3 player problem fwd0120 Gear, Equipment, Recording & Off Topic 13 02-04-2011 10:24 AM
Weird Tuning Problem newbieguitarmaker Tech: Setup, Repairs and Mods 17 08-05-2007 12:04 PM
Weird problem Jack Secret Tech: Setup, Repairs and Mods 2 07-20-2006 10:51 PM
weird string problem Fry Ibanez JEM, UV, JS & Other Signature Models 11 01-02-2004 11:55 AM
Problem with my Morley PVO - Very weird! carlos seo Tech: Setup, Repairs and Mods 6 12-25-2001 10:30 PM
