Weird high pitch noise only on palm muted A-String - Jemsite
post #1 of 4 (permalink) Old 05-22-2017, 04:51 AM Thread Starter
Angry Weird high pitch noise only on palm muted A-String
Hello there!
Well, I heard there are some experts around here, so I hope you guys can help me.
I have an Ibanez RG450AH from '99 here and since a few days I am encountering a high pitch noise when doing palm mutes on the open A-string.
I recorded a soundfile with this noise so you can have a listen. Since I am new here and not allowed to post a link yet, please take this url and write "dropbox.com" before. It's basically in my dropbox. Hope this works, otherwise send me a message and I will give you the link.
Dropbox: /s/3aczgnk2v7n3iom/a-saite.mp3?dl=0
There is some kind of high frequency ringing noise going on. It appears ONLY on the open a-string when playing palm mutes. Nowhere else! If I play an A on the 5th on the E-string it's perfectly fine.
I tried a ton of things but none of them helped:
- Changing the Locking Nut
- Putting Foam around the Tremolo springs
- Putting Foam underneath the strings behind the nut
- Putting Foam underneath the Pickups!
- Raising the string action (the guitar is set-up well!!)
When tuning down the a-string a halfstep the noise is still there. So obviously it should be the Nut right? But no... I changed that too.
Looking forward to hear from you!
Stefan
Stefanowitsch is offline
post #2 of 4 (permalink) Old 05-22-2017, 08:36 AM
site founder 0% owner
jemsite's Avatar
Re: Weird high pitch noise only on palm muted A-String
It almost sounds like a bad harmonic coming off your palm or bridge (not nut) based on how tight it is with the attack. The foam is more for squeals from sympathetic notes coming back to the trem springs.
What tremolo is this?
You should isolate a few things...
if the RG has a locking stud make sure it's locked. check the saddle for crack/damage.
if it is related to pick strength/attack. does the sound occur with a light attack? heavier attack?
does it happen if the A is not muted
does it happen at std tuning
raise low E side action more does it eliminate the problem.
Gotta keep working thru it.
jemsite is offline
post #3 of 4 (permalink) Old 05-22-2017, 10:25 AM Thread Starter
It's an LO-TRS I Tremolo.
Locking studs are locked tight. Saddles are absolutely fine!
The sound is always present, no matter how hard or soft i pick. But its only there when I palm mute the string!
When playing the string normally, there is no pitch noise.
I'm playing in standard tuning but tuning up/down does not solve the problem either.
I can vary the string action from very low to very high but is does not affect the noise.
post #4 of 4 (permalink) Old 05-22-2017, 10:34 AM
jemsite's Avatar
is it safe to assume if another player palm mutes open A the sound is not heard or exactly the same?
if you play palm muted slower (quarter notes 60bpm) downstroke only is it heard?
if you play PM up and down is it heard?
jemsite is offline
Weird sort of string-buzz on high e-string on my RG Premium Santuzzo Tech: Setup, Repairs and Mods 12 04-06-2014 09:25 AM
Muted open string TheEYE Tech: Setup, Repairs and Mods 6 03-21-2013 10:50 AM
nasty noise from prestige rg (that high fret warbling noise that you DONT want) superhairycamel Tech: Setup, Repairs and Mods 10 07-04-2008 08:00 AM
weird noise Spooty777vai Tech: Setup, Repairs and Mods 3 06-11-2007 01:34 PM
Weird noise problem zEr0 Tech: Setup, Repairs and Mods 15 06-03-2004 02:26 PM
