What exactly was wrong with the Edge III? - Jemsite
post #1 of 7 (permalink) Old 02-02-2016, 09:49 PM Thread Starter
I've heard that the Edge III gets a bad rap. I'm curious as to why? Does anyone know exactly what was wrong with it mechanically?
I have a friend who is a CNC guru, he told me he can make a new blade for me for my Edge III and while he's making me a new part (stainless steel), I'm wondering what if any other parts there are that he could possibly make that would turn this into a better tremolo.
Anyway, thanks for any feedback.
RickBlacker is offline
post #2 of 7 (permalink) Old 02-02-2016, 10:54 PM
Reviews: 120
Re: What exactly was wrong with the Edge III?
The problem is probably mostly based around the metallurgy of the parts. By blade do you mean a replacement baseplate? The knife edges far as I can recall are all attached to the baseplate, so if you're having a new baseplate made up, combine that with higher quality posts and you'll most likely end up with a reasonably functional long lasting bridge.
LonePhantom is offline
post #3 of 7 (permalink) Old 02-02-2016, 11:31 PM Thread Starter
Hi Lone... Yes, I do mean baseplate. Also, I am going to have him make new posts as well. My posts show a little sign of wear on them as well. No sense in having a nice stainless steel plate made just to cut into soft posts.
post #4 of 7 (permalink) Old 02-02-2016, 11:43 PM
Stainless is the last thing you want. You want hardened steel. Hardened after it's cut of course.
Rich is offline
post #5 of 7 (permalink) Old 02-03-2016, 12:36 AM Thread Starter
What's wrong with stainless steel?
post #6 of 7 (permalink) Old 02-03-2016, 01:20 AM
Stainless steel is generally a lot less hard wearing than other steel alloys, especially heat treated ones. The main reason stainless steel is used in anything is corrosion resistance.
Roachy is offline
post #7 of 7 (permalink) Old 02-28-2016, 08:59 AM
grt
after a conversation i had with the guy who set up my guitar ,he tells me that ibanez use soft steel and this the reason why the system broke or damaged easy.original floyd rose use hard steel and the problems there is almost zero.also you can find the smallest part of floyd rose separate in market ,you dont need to change all the system in something broke or damaged
grt is offline
Did I do something wrong? RockHardGuitars Classified Ads: Guitars and Gear 3 07-26-2012 02:37 PM
What's wrong here? Xavier 7 Ibanez JEM, UV, JS & Other Signature Models 5 02-21-2005 03:15 PM
Something wrong with this... geetarmonkey Vendors, Auction & Reseller Talk 6 06-07-2004 12:20 PM
whats wrong with my edge pro? al885 Tech: Setup, Repairs and Mods 4 09-02-2003 10:26 AM
wah is wrong with my wah? lwi Gear, Equipment, Recording & Off Topic 22 02-05-2001 09:53 PM
