What's the Best Glue for Guitar Repairs? - Page 2 - Jemsite
post #16 of 18 (permalink) Old 05-15-2006, 03:06 PM Thread Starter
Wink Re: What's the Best Glue for Guitar Repairs?
Originally Posted by ryanb
I wouldn't use it for building a guitar. A glue that cannot be taken apart at all is not particularly desireable for a guitar, where parts often may need to be replaced/modified down the road. Try taking off a fretboard glued on with that stuff. Hide glue comes apart at much too low a temperature for me. Titebond is both plenty strong enough for the job, hard enough, and easy enough to get apart when necessary. It's also a lot easier to work with. There are definitely times super-strength glues are appropriate, but I dare say that if Titebond isn't strong enough for a joint on a guitar, you need a better physical joint.
$0.02
I agree with you there on some of the points you made, but the Selley's 308 wood glue is better for bonding say eg- a Neck thru body guitars ect- were you have to Glue up all the wood's used together to make the neck & or body as one solid structure, for fretboard repairs go with Titebond, But for say a repair were a chunk of the guitar body broke away , Or glueing up woods to make an electric guitar/ bass body- that there will be no need in future to take apart & you want it to last go with the Selley's 308, this glue is best used in place's that never need to be taken apart so make sure when using this glue to keep that in mind Ok! this glue is Super Strong!
jaken777 is offline
post #17 of 18 (permalink) Old 05-18-2016, 08:55 PM
Smile Re: What's the Best Glue for Guitar Repairs?
Try GluBoost. Specifically design for guitar repair. Gluboost.com to order online.
I have used for several years now for guitars and some furniture repair applications.
mbrownnyc is offline
post #18 of 18 (permalink) Old 05-19-2016, 01:29 AM
Titebond original for bare wood. Whatever you do don't use TB 2 or 3.
Zoot is offline
david mccarroll , electric guitar , guitar body , neck thru , neck thru body
What glue to use for graphic and fabric top guitar projects? TAorama Tech: Setup, Repairs and Mods 8 05-18-2012 03:11 PM
Wood glue & filler what kind should I use... Scott 74 Tech: Setup, Repairs and Mods 3 07-03-2005 07:40 AM
super glue on finish Dylan7620 Tech: Setup, Repairs and Mods 3 02-06-2004 07:30 PM
glue on JEM. HELP ME KurtCobain Tech: Setup, Repairs and Mods 11 06-15-2003 11:38 AM
Changing Vine inlay colors - things that make you go hmmmmmm tomizm Tech: Setup, Repairs and Mods 34 04-13-2001 03:14 PM
