whats the difference between an F-Space pickup and a regular - Jemsite
post #1 of 3 (permalink) Old 08-09-2001, 01:50 AM Thread Starter
I'm replacing the pickups on my RG520..someone told me I should get F-Space Dimarzio Evolutions, NOT the regular Dimarzio Evolutions?
is that correct?
whats the difference?
AJ Love is offline
post #2 of 3 (permalink) Old 08-09-2001, 03:11 AM
One Google search and I found this on the Dimarzio site:
"F-SPACING refers to a wider spacing between pole pieces available at no extra charge on all full-sized humbuckers. F-spaced pickups should be used in the bridge position an all guitars with wider string spacing, such as STRATŪs or guitars with tremolos. This assures proper string alignment and balanced output. On guitars with a nut width of 1&11/16" or greater, F-spaced pickups can used in the neck position as well. Please specify "F-spaced" at the time you place your order."
BTW, Ibanez RG guitars have a neck width of 43mm (~ 1 & 11/16) so I use F-spaced in the bridge AND neck positions.
Rick
rickboot is offline
post #3 of 3 (permalink) Old 08-09-2001, 03:32 AM Thread Starter
thanks Rick!!
for some reason when I searched I wasn't able to find that info
much appreciated
AJ Love is offline
bridge position , dimarzio evo , dimarzio evolution , dimarzio evolutions , neck position , spaced pickup
Any difference between regular S and S with flamed maple? kspeed All Other Guitars (including Prestige) 2 11-09-2010 05:21 PM
Whats the difference between... Watkins All Other Guitars (including Prestige) 1 05-07-2009 11:33 PM
rg whats the difference toma All Other Guitars (including Prestige) 11 07-03-2005 10:21 AM
Pickup Mounting - & pot resistance, whats the difference? EvilMonkey Tech: Setup, Repairs and Mods 1 03-12-2002 03:10 PM
F-space or regular ??? - What do I need for a jem 10th ?? BronzeMan Ibanez JEM, UV, JS & Other Signature Models 5 01-09-2002 03:05 PM
