When is an Edge too worn? - Jemsite
post #1 of 14 (permalink) Old 04-04-2017, 04:29 PM Thread Starter
As topic; When is the knife edge on an Ibanez Edge/Lo Pro Edge too worn to even consider filing smooth and keep using.
Got myself a 540R with the knife edge worn beyond anything I've seen before, can someone give their take on it?
Pirataz is offline
post #2 of 14 (permalink) Old 04-04-2017, 06:59 PM
Super Moderator
jono's Avatar
Re: When is an Edge too worn?
In my very limited experience with this sort of thing, Stick a fork in that, it's done.
jono is offline
post #3 of 14 (permalink) Old 04-04-2017, 11:12 PM
Reviews: 120
I'd try and file it back to shape. The inserts are hardened steel aren't they? You may have to adjust both sides and re-intonate the saddles, but if the trem in general is okay otherwise then definitely give it a go.
LonePhantom is offline
post #4 of 14 (permalink) Old 04-05-2017, 05:35 AM Thread Starter
Thanks for your replies. The trem is in very good condition for a guitar from 1988, much better in fact than my Jem505 which is considerably "younger".
Strange thing is that the left side knife edge looks almost new, so this must've been a major setup issue.
I'll give filing and intonation a go, I'll get back to you with the results
Pirataz is offline
post #5 of 14 (permalink) Old 04-11-2017, 04:06 PM Thread Starter
So, filed the knife edge a bit, has a bit better shape now but I'm very unsure. Would be amazing if there were any replacement knife edges available (but I won't beat that dead horse)
Overall condition, would be sad to get rid of as it's original -88:
Pirataz is offline
post #6 of 14 (permalink) Old 04-11-2017, 04:45 PM
Reviews: 10
I think your are setting yourself up for frustration here - I don't understand how you can make that work like that. I'm with jono -I think you need to move on and replace it. If you do try it then I will be curious to see how it goes...
doriangrey is offline
post #7 of 14 (permalink) Old 04-11-2017, 07:53 PM
Reviews: 120
Definitely looking heaps better, I'd be giving it a go. Just make sure you lubricate the pivot points, you may be right to go.
post #8 of 14 (permalink) Old 04-11-2017, 08:18 PM
Nicely done, make sure the edge is not sharp though, needs to be dull.
Bottom line the only criteria that matters is will it return to tune. If it does it's fine.
Rich is offline
post #9 of 14 (permalink) Old 04-12-2017, 06:16 AM
Reviews: 3
After filling that side I suppose you need to fill also the straight side to compensate both sides in order to avoid having the bass side far and the treble side closer to the pickguard. Finally it is possible to loose some clearance from the baseplate to the pickguard, so checking that and sanding down the pickguard must be needed, am I right?
vy100 is offline
post #10 of 14 (permalink) Old 04-12-2017, 09:32 AM
Like Rich said, if it works, then don't stress out about it.
Stealthtastic is offline
post #11 of 14 (permalink) Old 04-12-2017, 03:43 PM
I've taken more abused trems back from the brink, back to holding tune really well. My guess is with some lube it will be fine.
BigBazz is offline
post #12 of 14 (permalink) Old 04-17-2017, 05:49 AM Thread Starter
Thanks, yes I'll give it a go when the rest of the guitar is up to par as well
Thanks Rich, means a lot coming from you. I've read the guide on your webpage many times, and have performed it on at least 3 guitars with excellent results, and I very much hope this one will be able to properly return to zero as well.
Nah, it's nothing extreme in terms of distance compared to the straight side, so a simple intonation will likely suffice. The 540r does not have a pickguard, so that won't be a problem.
That's what I'm hoping for here as well, thanks for your input!
Pirataz is offline
post #13 of 14 (permalink) Old 04-23-2017, 04:07 PM Thread Starter
Not super bad, but not super good either. At least the trem isn't touching the body anywhere.
Have not tried making it floating yet, but wish me luck!
Pirataz is offline
post #14 of 14 (permalink) Old 04-23-2017, 10:24 PM
Reviews: 120
I'm sure once it's set up it'll be fine
Are these knife edges worn-out? AkselBT Tech: Setup, Repairs and Mods 6 04-12-2014 04:12 PM
RG350DX with worn Edge III springs? bcarroll2k3 All Other Guitars (including Prestige) 15 07-08-2011 06:38 AM
Fender Road Worn Series chopvai All Other Guitars (including Prestige) 3 06-24-2010 12:53 AM
Edge III worn in 2 weeks Vikingguitar Tech: Setup, Repairs and Mods 5 08-19-2008 01:18 AM
What do worn knife edges look like? Devine Tech: Setup, Repairs and Mods 0 02-15-2001 11:57 PM
