Where to find Trem post (locking screw) mod kit ? - Jemsite
post #1 of 8 (permalink) Old 04-06-2008, 08:00 AM Thread Starter
Hi everybody!
Following RIch's tuning stability problems section , i streched all the strings and they now perfectly stay in tune when diving the bar. But they good a little sharp when Pulling the trem.
SO i thoug it could be a Trem post Problem , because i haven't the locking studs mounted
SO can everybody tell me where i can find them? I watched on COTTAM GUITARS , but i don't know where i can order it through the site ( i can't find them on the part section.)
Thanks.
Vaistarr is offline
post #2 of 8 (permalink) Old 04-06-2008, 09:58 AM
Re: Where to find Trem post (locking screw) mod kit ?
Ummm I believe Rich has those conversion kits as well....Just go to his parts section.
TMatt142 is offline
post #3 of 8 (permalink) Old 04-06-2008, 05:15 PM
Originally Posted by Vaistarr View Post
because i have the locking studs.
bu what are you gonna mod if you already have the locking studs?
rvai is offline
post #4 of 8 (permalink) Old 04-06-2008, 07:10 PM Thread Starter
Sorry I made a mistake. Of course i have the basic trem post ( not lockin ones )
Vaistarr is offline
post #5 of 8 (permalink) Old 04-06-2008, 07:13 PM
Max sells them, drop him an email, I sell them, drop me an email, but don't expect 100% return even with the stud mod. It should improve return if you've thinned the knives correctly and lubed the contact points though.
Rich is offline
post #6 of 8 (permalink) Old 04-07-2008, 11:39 AM
Reviews: 13
Before you bought the lock post, try this option 1st.
Ok before lubing up, take off the whole damn tremolo and the screw stud, get hold of a sealing tape, dirt cheap, normally it is use for piping installation to prevent from leaking.
Wrap up a few rounds or to desired amount clockwise on the screw stud, Screw it back to the stud mounting nut on the guitar. Make sure the stud is tight. Shake it left and right to ensure it sits tightly.
Lube up the stud groove and your trem knife edge.
Next mount your tremolo with the springs and restrung the guitar, adjust slowly both the studs height to your liking.
1 disadvantages is that do not turn it anticlockwise to loosen it up, you will have to reseal the stud back with the sealing tape, so make sure you get the correct height the 1st time without unscrewing back the stud.
Try this option, super cheap and stays intune.
Zepp3lin is offline
post #7 of 8 (permalink) Old 04-07-2008, 11:55 AM
Originally Posted by Zepp3lin View Post
...do not turn it anticlockwise to loosen it up, you will have to reseal the stud back with the sealing tape...
i use this trick some years now, but i haven't really had problems loosening the studs and/or adjusting their height many times until i find desired strings action. the studs would stay pretty locked even then.
anyway, it's a great improvement at a ridicolous cost.
nuno is offline
post #8 of 8 (permalink) Old 04-08-2008, 11:47 AM
Reviews: 13
Yes nuno, your the man, I thought I'm the only one thought of it and sharing the idea. It's very effective and the stud is holding tight in there without any movement.
The reason is normally a sealing tape will lose it's sealing properties once you remove it or turn it anticlockwise, so the best is do some marking on the stud before hand and tightened it clockwise once without turning back.
Zepp3lin is offline
cottam guitars , locking stud , locking studs
Trem post set screws - I found them and they fixed my woes! bachle7 Archived Topics and Common Questions 46 05-31-2009 08:37 PM
single locking trem dimefan90 All Other Guitars (including Prestige) 6 04-01-2008 09:08 AM
double locking trem thc303 Tech: Setup, Repairs and Mods 0 04-10-2003 10:28 AM
tool to remove the trem post set screws schmintan Tech: Setup, Repairs and Mods 2 02-05-2003 02:09 PM
Broken locking nut screw. Noodles Tech: Setup, Repairs and Mods 5 01-01-2001 09:36 AM
