Whooshing noise from EMGs in RG8320, possibly battery compartment related - Jemsite
post #1 of 7 (permalink) Old 01-15-2012, 09:21 AM Thread Starter
Hi, I wonder if anyone can help - I have an RG8320 fitted from the factory with active EMGs and a 9V battery compartment. Recently I've started getting huge amounts of variable loud noise when plugged in - as loud as the actually guitar tone. Sounds like whooshing wind effects rather than pickup hum. I've checked for loose connections and there's no obvious solder breaks, used switch cleaning lubricant on all relevant parts and still no luck.
The battery compartment looks like it's one of these:
http://www.allparts.uk.com/online-sh...st-p-4023.html
If there's no obvious solution I'll get a replacement one of these and resolder, see if that fixes it.
Dan_H is offline
post #2 of 7 (permalink) Old 01-18-2012, 06:03 PM
Re: Whooshing noise from EMGs in RG8320, possibly battery compartment related
perhaps a grounding issue? have you checked your grounding connection?
snickersvickers is offline
post #3 of 7 (permalink) Old 01-27-2012, 09:11 PM Thread Starter
Thanks for the suggestion but grounding seems ok - there's a black wire still firmly soldered to the trem claw from the tone pot. Think I'll try a new battery compartment and see if that's the problem.
Dan_H is offline
post #4 of 7 (permalink) Old 01-28-2012, 02:23 PM
Active EMG's are not supposed to be grounded to the bridge at all. They are grounded internally (meaning inside the pickups themselves). That could be causing your problem.
CSwick_2 is offline
post #5 of 7 (permalink) Old 04-01-2012, 10:58 AM Thread Starter
Thanks for the advice, but I ended up earmarking this guitar for a pickup swap rather than troubleshoot the dodgy wire :-)
Crunch Lab and Liquifire plus suitable vol & tone pots installed. Too early to give a full review but early indications are that I'm liking the new combination. Playing crunchy metal riffs, the Crunch Lab has added a bit more beef to this alder bodied guitar in Drop C. The EMG81 always sounded a little hollow. Surprised how hot the Liquifire is though - sounds like a bridge pickup, voicing very similar to the Crunch Lab. I think I preferred the EMG85 neck as it had a natural bluesy character to it and more contrast with the bridge pickup. (This is just using existing favourite patches so I'm sure there's more nuances I can get out of both pickups as I experiment.)
Dan_H is offline
post #6 of 7 (permalink) Old 04-01-2012, 11:17 AM
RGTFanatic's Avatar
The important Q is: Did the noise go away???
The sound you were describing sounded more like a pre-amp or maybe an environmental issue.
RGTFanatic is offline
post #7 of 7 (permalink) Old 04-01-2012, 05:05 PM Thread Starter
It wasn't environmental, it must have been down to either the grounding, broken soldering, or a bad battery compartment as it's absolutely fine now, despite some initially poor soldering from me on Friday. I'm much better at it now than I was at the start of the weekend!
Dan_H is offline
battery , compartment , emg , noise , rg8320
Battery compartment Safety Alert horstausmforst Jemsite Featured News 19 06-19-2017 07:37 AM
How do I remove the battery compartment on RG8320/RG8420/RG8327? Dan_H All Other Guitars (including Prestige) 1 04-01-2009 08:12 AM
Routing for EMG 9v battery compartment. Any advice? Stygian Tech: Setup, Repairs and Mods 11 03-17-2008 03:22 PM
New J-Custom RG8420 vs RG8320: Thoughts on mahogany or alder with EMGs Dan_H All Other Guitars (including Prestige) 3 05-25-2007 08:52 AM
Replacement EMGs - battery cavity query... germX Tech: Setup, Repairs and Mods 7 01-19-2001 02:33 AM
