Wierd trem noise - Jemsite
post #1 of 3 (permalink) Old 11-30-2003, 11:00 AM Thread Starter
Wierd trem noise
When I strike the g-string on my rg 1570 the trem is making a kind of "rattling" sound. Is there anything I can do to solve this problem?
thc303 is offline
post #2 of 3 (permalink) Old 11-30-2003, 06:59 PM
It may be the springs. Put a bit of cotton in the trem cavity & replace the cover.
Dr_Guitar is offline
post #3 of 3 (permalink) Old 12-01-2003, 08:19 PM
Wedge a guitar pick or toothpick on either side of the saddle. Not the part bolted to the baseplate, but the part that the string goes into. If that stops it, you have a loose saddle. That means the area where the pin goes through the saddle, and therefore holds it to the other part in front of it, has too much play in it. They have to have some play for the fine tuners to work but sometimes the saddle will rattle, or the pin rattles. (Dr Seuss look out) If so, you can put a blob of linseed oil in there, where the pin goes through, and let it dry. It won't actually dry, it'll just get gummy, and should stop the noise.
But it really could be anything, while the G string just happens to be at the frequency or the location on the bridge to bring it out.
frankfalbo is offline
Tiny noise from the neck pocket when using the trem Professor Jones Tech: Setup, Repairs and Mods 8 08-13-2013 07:06 PM
Clunky trem noise johnny_alpha Tech: Setup, Repairs and Mods 4 09-26-2012 05:41 PM
JS 1200...warbling when pickign hard, trem noise etc... KissMyAxe Ibanez JEM, UV, JS & Other Signature Models 6 02-19-2006 08:45 PM
Trem is acting wierd Pikaciao Tech: Setup, Repairs and Mods 2 11-28-2005 08:25 PM
Trem Bar Noise!!! Frankie Tech: Setup, Repairs and Mods 19 07-02-2002 11:00 PM
