Will Dimarzio Vol Tone pots fit Ibanez knobs ?? - Jemsite
post #1 of 10 (permalink) Old 04-26-2013, 06:13 AM Thread Starter
IbanezFreak777's Avatar
Reviews: 25
Beside the fitting, which should I be buying 250k or 500 k??
The only reason I ask, is the dimarzio switch tips dont fit the Ibanez switch tip covers, so Im worried they wont match up etc..
Cheers !!
these are the pots im looking at buying
http://www.ebay.com.au/itm/DiMarzio-...632ff2f&_uhb=1
IbanezFreak777 is offline
post #2 of 10 (permalink) Old 04-26-2013, 10:33 AM
RGTFanatic's Avatar
Re: Will Dimarzio Vol Tone pots fit Ibanez knobs ??
Probably not J,
The length works well on rear route bodies, but the shaft diameter is larger than the bore on a standard body or pickguard. It's obviously not hard to open the bore up a little to accommodate the shaft, but I thought you'd want to know that.
I prefer a 250 audio taper on the vol with a treble bleed cap and a 500k linear taper on the tone with a .068Mfd tone cap, but that's just my preference. The guitars construction/wood type/pickups is usually what determines my choices.
RGTFanatic is offline
post #3 of 10 (permalink) Old 04-26-2013, 11:10 AM
You can make the plastic knobs fit, but that's about it. Probably the newer metal set screw knobs as well. UCGR's had DiMarzio pots. Any metal push-on knob probably won't fit.
Takin' a Ride is offline
post #4 of 10 (permalink) Old 04-26-2013, 04:48 PM
Reviews: 120
500k is the norm for humbucker equipped guitars.
LonePhantom is offline
post #5 of 10 (permalink) Old 04-26-2013, 11:38 PM
Reviews: 11
Bourns, cts, alpha, dimarzio, evh, all use 6 mm shafts for their split shaft pots.... all normal push on knobs will fit.
For pot value, humbuckers standardly use 500k ohm exponential taper (audio taper).
linuxpenguin is offline
post #6 of 10 (permalink) Old 04-27-2013, 03:36 AM Thread Starter
Reviews: 25
Is that 500k on Vol and Tone ?
post #7 of 10 (permalink) Old 04-27-2013, 03:42 AM
Reviews: 11
correct. However, its totally dependent on taste. I think one day, I would like to try an EVO pickup wit ha 250k pot! Should curve out the overly bright (to my ears) highs and make it less vowel-like. But the higher resistance you go, the less highs get "chopped", I think it has to do with treble bleeding on lower resistance levels, although I won't pretend to know the first reason as to WHY that happens haha.
That said, the standard is 500k for both, with .47mF resistor for tone
edit: dude, save your money... buy some alpha of CTS pots for cheaper... same exact quality, half the cost. Dimarzio charges more simply because "they can"
post #8 of 10 (permalink) Old 04-27-2013, 03:47 AM Thread Starter
Reviews: 25
Ok I will look for them on ebay.. Cheers !!
post #9 of 10 (permalink) Old 04-27-2013, 04:10 AM
Reviews: 11
Sorry, typo! Alpha OR (not "of) CTS pots. Id simply edit but I wanted to make sure you see it.
post #10 of 10 (permalink) Old 04-27-2013, 05:39 AM Thread Starter
Reviews: 25
Thanks
WTB: Blue DiMarzio vol/tone knobs and switch tip Dr.StrangeNote Classified Ads: Guitars and Gear 5 05-03-2010 09:51 PM
WTB Green Ibanez Volume Tone Knobs Ibanized Classified Ads: Guitars and Gear 0 03-12-2010 04:01 PM
Swirling Ibanez VOL TONE TIP Knobs.. ? Possible IbanezFreak777 Tech: Setup, Repairs and Mods 1 09-11-2009 01:29 PM
Strat knobs for solid shaft pots? Dee Tech: Setup, Repairs and Mods 3 03-09-2007 04:23 PM
WTT Ibanez Universe Volume & Tone Knobs Mission1979 Classified Ads: Ibanez JEM/UV Guitars 0 02-14-2007 03:11 PM
