Will EMGs fit in RGT42DX? - Jemsite
post #1 of 8 (permalink) Old 01-10-2006, 11:04 AM Thread Starter
hi
i m planning to purchase a rgt42dx and replace the pickups to emgs
the question is...will there be any routings needed?
how will the circuit go if i add a 85 to the neck and 81 to the bridge??
sugizo_esp is offline
post #2 of 8 (permalink) Old 01-10-2006, 12:03 PM
Re: Will EMGs fit in RGT42DX?
no routing the shop you grt them instaslled in should remove all the old electronics and install emg active electronics no routing, thats what theyd do in my local emg stockist
jem_fanatic is offline
post #3 of 8 (permalink) Old 01-10-2006, 04:33 PM
No routing need for 6-string EMG pickups. There's only some routing needed for 7 string EMG pickups since the pickups are housed in bass pickup housing. Dunno what you mean regarding the circuit though.
buddroyce is offline
post #4 of 8 (permalink) Old 01-10-2006, 05:10 PM
Well, SOME 6 string guitars need routing to fit EMGs (RGAs, for instance) but any guitar with pickup rings won't have any trouble. All the electronics will have to be replaced with EMG electronics but it should all come with the pickups if you buy them new.
lyconxero is offline
post #5 of 8 (permalink) Old 01-10-2006, 08:55 PM
EMG's have sharp corners. Some guitars, even with mounting rings will not fit an EMG because the route is rounded at the corners. Also some guitars have a shallow route, and the EMG's are rather deep. But all the Korean routes, including the RGT's are oversized, and they will fit EMG's with no problems at all.
frankfalbo is offline
post #6 of 8 (permalink) Old 01-10-2006, 10:04 PM Thread Starter
thx guys
the input jack need to be replaced aswell rite??
post #7 of 8 (permalink) Old 01-11-2006, 12:32 AM
Yes, you should replace the tone and volume pot along with the input jack. As I mentioned before, if you buy the pickups new then they'll come with all of that and you'll just have to install it all (or have a professional do it because installing EMGs can be a little tricky).
post #8 of 8 (permalink) Old 01-11-2006, 01:51 AM Thread Starter
yep..i m getting the emgs new...okok..thx
everythings cleared
emg active , emg active electronics , pickup ring , pickup rings , string guitars
Pin striped my new rgt42dx Josh_P All Other Guitars (including Prestige) 9 05-11-2010 07:13 AM
RGT42DX Pics Watkins All Other Guitars (including Prestige) 5 03-11-2010 01:31 PM
RGT42DX Fretwire? hellboar All Other Guitars (including Prestige) 2 10-16-2009 06:50 PM
New RGT42DX chrisgr All Other Guitars (including Prestige) 15 02-17-2009 02:36 AM
f/s rgt42dx(white) spider murphy Classified Ads: Guitars and Gear 7 06-29-2007 06:41 PM
