Will StewMac Floyd Rose routing templates work for Edge? - Jemsite
post #1 of 5 (permalink) Old 12-28-2003, 01:01 PM Thread Starter
Are the StewMac routing templates for Floyd Rose tremolos the same dimensions as the Edge and/or LoPro cavities? If not, is there a source for Edge and LoPro routing templates?
TAorama is offline
post #2 of 5 (permalink) Old 12-28-2003, 05:43 PM
http://www.ibanezrules.com/catalogs/...dge_manual.pdf
Don't forget to post pics when you're done, good luck
horstausmforst is offline
post #3 of 5 (permalink) Old 12-29-2003, 06:57 PM Thread Starter
What about the template to recess the top of the body? That's not in the Edge manual. StewMac sells one that they say is for Floyd and Schaller trems. By choice, I don't have anything non-Ibanez in my house to compare with to see if the dimensions are the same.
TAorama is offline
post #4 of 5 (permalink) Old 12-29-2003, 07:15 PM
If you must use a template, you can get the Stew-mac one, locate it for the left side, cut the left side, then reposition it on the right side, etc. I haven't seen the Stew-mac one but I would assume it's symetrical. That could be your only problem, if it was slimmer on the bass side, because that's how the Schaller & some Floyd baseplates are cut. If you call, the Stew-mac reps should be able to answer this one for you. Otherwise you can make your own template from acrylic.
I just measure and tape it off once the trem is in place, and route it. I prefer the back of the cavity (under the fine tuner area) to angle inwards, making a trapezoid instead of a rectangle. The edge angles that way, and I think it looks cool.
frankfalbo is offline
post #5 of 5 (permalink) Old 12-30-2003, 07:46 AM
Oops... I've never noticed that. It'd be interesting to find out if the top routing measurements were included in the (newer) Lo-Pro Edge kit.
Anyway, this might help you. But be careful, some measurements vary inside that thread.
http://projectguitar.ibforums.com/in...?showtopic=633
floyd rose , floyd rose trem , floyd rose tremolo , pro edge , schaller trem
Edge Zero routing templates? RG Loyalist Tech: Setup, Repairs and Mods 0 04-29-2012 09:53 PM
making templates for filling in cavities for pickups and floyd rose for mods rg-ninja Tech: Setup, Repairs and Mods 5 02-02-2010 06:02 AM
floyd rose pro routing on TREMONTI SE? bjamin86 All Other Guitars (including Prestige) 9 03-11-2007 08:55 PM
Floyd Rose Routing SuperJemBoy Tech: Setup, Repairs and Mods 3 05-24-2004 09:09 AM
Floyd Rose Cavity: Lo Pro Edge same as Original Floyd rose - Captain Ron Tech: Setup, Repairs and Mods 2 09-06-2001 12:06 AM
