Will this work ? - Jemsite
post #1 of 7 (permalink) Old 09-16-2011, 09:42 AM Thread Starter
IbanezFreak777's Avatar
Reviews: 25
Will this work ?
Ok so, im putting together a new pedal board. Got the Voodoo Labs power plus 2 setup and its all working great.. It has a courtesy outlet for an IEC cable i think its called.
What I want to do is, connect that particular plug to a 4 board power outlet, and install that in the underside of my pedal board so I can plug other pedals that cant be powered by the voodoo..
so check out this picture and let me know what you think.. !!
This is what I made.. obviously will be soldered and taped off later
and this is where it would get powered from. socket on the left
IbanezFreak777 is offline
post #2 of 7 (permalink) Old 09-16-2011, 01:43 PM
RGTFanatic's Avatar
Re: Will this work ?
you want to power the power strip with the voodoo using this method? Am I understanding correctly??
As long as your not drawing too much current (3amps?) through the voodoo you should be OK. Does the voodoo have an internal fuse in line for that particular plug? and what is the amp rating for that fuse (if it has one)?
RGTFanatic is offline
post #3 of 7 (permalink) Old 09-16-2011, 01:57 PM
Reviews: 11
As long as that particular outlet doesnt have a surge protector or power conditioner built in, it will be fine.
linuxpenguin is offline
post #4 of 7 (permalink) Old 09-16-2011, 02:40 PM
jb4674's Avatar
Reviews: 18
I'd say do the opposite and run current from the wall to the power strip and use one of those outlets for the PP2+.
Jimmy
jb4674 is offline
post #5 of 7 (permalink) Old 09-16-2011, 08:06 PM Thread Starter
Reviews: 25
Jimmy
Yeah but that makes to much sense :P I already installed a IEC connection for the PP2 in my new pedal board...
I will check it out at the voodoo lab forum and if its a no go, your idea, makes the most sense.
Cheers
post #6 of 7 (permalink) Old 09-16-2011, 08:13 PM
Reviews: 98
That should work just fine. Just beware of which lug is which--polarity and ground wise.
AlaskaBat is offline
post #7 of 7 (permalink) Old 09-16-2011, 09:19 PM Thread Starter
Reviews: 25
both cables have the same color wires... so i just match them up I assume
Anyone here work out? Necrojem Off-topic / Miscellaneous 103 06-10-2007 03:57 PM
How to work out which JEM to buy? fastonebaz Ibanez JEM, UV, JS & Other Signature Models 27 12-18-2005 06:14 AM
Last day of work... Knightmeir Off-topic / Miscellaneous 8 09-28-2005 06:46 AM
