wood squeaking using the Lo-Pro - Jemsite
post #1 of 10 (permalink) Old 09-16-2004, 05:39 AM Thread Starter
I've JUST noticed this: I recently bought an used rg2027. When I 100% depress the bar (pull-down) I hear a squeaking-wood noise located inside the neck pocket. In fact, after a full bar depression, if I push with a little force the neck area close to the body, I hear another subtle squeak and then nothing more. Seems like the neck is not totally sit on the pocket...The 4 neck screws are already very tight. I've checked the neck and body area near the pocket and there aren't any cracks or similar. Maybe shims are needed in the neck pocket? Please help!
Pesso is offline
post #2 of 10 (permalink) Old 09-16-2004, 11:31 AM
We talked about this a long time ago, like years ago, so I don't know if it'll come up in a search. Take the neck off when you're restringing some time and clean out in there with a flat file, or even 600grit sandpaper. (lightly) Then take a countersink and countersink the screwholes in the neck slightly, to remove any lifting wood that may be affecting your compression. Then make sure that when you're screwing it back on it's pressed in tightly. Some guys put baby powder in there before reassembly. Its usually not a big problem but it is annoying.
Oh if all else fails, take the whammy bar out.
frankfalbo is offline
post #3 of 10 (permalink) Old 09-16-2004, 01:24 PM
The majority of the time pocket creak on an ibanez is from the side of the pocket. First make sure the strings are properly alligned on the neck. You should find the neck is tight on one side of the pocket and you want to relieve that side of the pocket just enough to let it breath and not creak. I use 220 wrapped around a rule. Don't go any lower in grit or it will flake the paint on the edge of the pocket.
Rich is offline
post #4 of 10 (permalink) Old 09-16-2004, 01:42 PM Thread Starter
So this fact is not harming my guitar at the moment, right? Should I fix this straightaway or can I do it in a few months? Because the squeaking doesn't annoy me (it happens only on 100% depress, when the bar tip is very close to the body!), so if this DOES harm my guitar, I would take care of this asap!
Pesso is offline
post #5 of 10 (permalink) Old 09-16-2004, 01:45 PM Thread Starter
Yeah, in fact the neck is tight on one side (the squeaking one, I seem to hear) and quite loose on the other (I can stick a paper on it, while on the first I can't).
But is this only a fix to get rid of the squeak or I MUST fix it otherwise I would damage my guitar?
Pesso is offline
post #6 of 10 (permalink) Old 09-16-2004, 01:51 PM
Nothing is being damaged if it is pocket creak but the first thing you should do is check that the strings are perfectly alligned.
Usually you only get pocket creak when switching trem directions. Pullup it creaks once, push down it creaks once. It usually doesn't keep creaking just using the trem in one direction so I'm not positive pocket creak is your problem. Move the neck over just enough to relieve that side and test it to be sure.
Rich is offline
post #7 of 10 (permalink) Old 09-17-2004, 06:34 AM Thread Starter
How can I do that?
Another thing: can this issue affect tuning stability?
Thanks for your help Rich, really appreciated as usual!
Pesso is offline
post #8 of 10 (permalink) Old 09-19-2004, 12:39 PM Thread Starter
How can I do that?
Pesso is offline
post #9 of 10 (permalink) Old 09-20-2004, 04:03 AM
No effect on stability.
Loosen the neck screws 1/4 turn, move neck, tighten. Strings at full pitch, no need to detune. The retune after you shift the neck.
Rich is offline
post #10 of 10 (permalink) Old 09-20-2004, 04:44 AM Thread Starter
Thank you very much Rich, I'll try this tomorrow!
Pesso is offline
neck screws
Squeaking trem bar on Edge Zero What's up??? DsrkHorse All Other Guitars (including Prestige) 8 04-15-2012 11:23 PM
Knots in wood and overall quality of prestige wood deathmetallist3 All Other Guitars (including Prestige) 5 08-01-2010 10:05 PM
Has anyone gone to a wood workshop with design+wood and gotten a CNC'd body? Ki swordsman Tech: Setup, Repairs and Mods 13 06-30-2007 12:33 PM
Jem wood versus gibson wood. jemke Ibanez JEM, UV, JS & Other Signature Models 8 12-06-2002 02:30 PM
Wood types for a universe body? - What wood type has a thick FORTHELOVEOFSWIRL Gear, Equipment, Recording & Off Topic 3 09-08-2001 08:17 AM
