Worn truss rod nut problems - Jemsite
post #1 of 3 (permalink) Old 01-30-2019, 07:19 AM Thread Starter
Hey guys I was trying to go through the steps mentioned in the the tech section regarding truss rod setup. My guitar is a RG550 from 1991 that I bought used and that I have not made any truss rod adjustment on yet.
Problem is, the hex wrench (ibanez multitool) does not move any further on the nut than those wear marks, even if I push it hard from behind. I don't want to turn it that way, unlike some previous owner (obviously). It almost seems there is not enough space below the nut to fit the tool... Any ideas?
mobei is offline
post #2 of 3 (permalink) Old 01-30-2019, 07:59 AM
Re: Worn truss rod nut problems
I had an 540P many moons ago with very little space between the nut and the wood. At the end I filed down the ring of a regular box spanner to get it onto the nut.
oliver_p is offline
post #3 of 3 (permalink) Old 01-30-2019, 03:49 PM
i have had a couple of instances like yours. I just found the right sized socket put an extension on it and hammered the socket on to the truss rod nut. I didn't go crazy on the hammering, it is pretty easy to break the neck, but a smaller rubber mallet did the trick. I couldn't really think of an easier way to go.
j.arledge is offline
rg 550 truss rod nut worn
Truss Rod Problems...temperature change is the cause? Smitty Tech: Setup, Repairs and Mods 14 04-09-2008 07:27 PM
help with truss rod: trying to loosen, but the nut FALLS OFF ddk Tech: Setup, Repairs and Mods 4 05-07-2004 07:10 PM
Help with my Radius 540 truss rod/nut gkelm Tech: Setup, Repairs and Mods 15 09-23-2002 08:19 PM
looking for shims for my UVGR locking nut - also a truss rod Superuser Tech: Setup, Repairs and Mods 8 03-21-2002 04:27 PM
Replacing Truss Rod Nut? kirk Tech: Setup, Repairs and Mods 3 11-17-2001 11:20 PM
