would screwing holes in finish for pickguard crack or ruin the finish - Jemsite
post #1 of 5 (permalink) Old 11-29-2009, 03:40 PM Thread Starter
i was going to add a pickguard and an emg PA2 on my guitar and was sondering if it would leave damage the rest of the finish *cracks,etc. its my rg370dxgp4, i believe its a polyester finish.pickga
l0k1 is offline
post #2 of 5 (permalink) Old 11-29-2009, 03:42 PM
elcid's Avatar
Re: would screwing holes in finish for pickguard crack or ruin the finish
Just pre-drill the holes and you'll be fine.
elcid is offline
post #3 of 5 (permalink) Old 11-29-2009, 03:52 PM
Jaden's Avatar
pre drill and then most important, slightly countersink the hole afterwards.
this prevents the screw thread that is pulling its way into the material (and therefore trying to lift the material and paint on top of it) from cracking the finish.
Jaden is offline
post #4 of 5 (permalink) Old 12-02-2009, 10:14 PM Thread Starter
k thanx guys
do you know where i could get a black RG pickguard for pretty cheap?
l0k1 is offline
post #5 of 5 (permalink) Old 12-03-2009, 12:48 AM
Check evilbay. Item number 370290847045.
dimarzio562 is offline
finish , modifications , pickguard
Finish crack on new IBANEZ S470B-SKB ANThology Tech: Setup, Repairs and Mods 0 10-11-2009 04:10 PM
Jem BRMR, does the finish still crack on these or is it a myth? chris101 Ibanez JEM, UV, JS & Other Signature Models 46 01-05-2007 07:08 AM
Typical Surface finish crack JimboWizbo Tech: Setup, Repairs and Mods 4 08-30-2006 02:43 PM
Stress crack on neck joint, or just a finish crack? m0p Tech: Setup, Repairs and Mods 6 11-09-2005 05:59 PM
7dbk finish crack - it's crakced... :( Jeroenn Tech: Setup, Repairs and Mods 1 08-01-2001 12:36 PM
