YJM pot lug grounding ideas/suggestions - Jemsite
post #1 of 2 (permalink) Old 09-15-2011, 07:39 PM Thread Starter
i recently purchased a SD YJM pot and i am having trouble grounding it.usually i am able to bend back the #1 lug to the pot and solder it, but with this particular pot, i cannot.Trying to do so, bent and teared the lug slightly, cause they are very short and not flexible.the lugs seem to be made of a harder material then others.i did managed to fix it with some solder though.
i went with soldering everything without trying to solder the lug to the pot and i was not able to control the volume by turning the knob.
after that i decided to use a cut off leg from a capacitor, soldered that to the lug and to the back of the pot.now i was able to get to control the volume but then i started to get a lot of noise.
i am gonna try to insulate the open wire and see if that helps, but overall i would like some help or suggestions, I've never had this much trouble installing a pot.
my wiring setup is very basic, 2 hum 1 vol, 3 way tele selector in a ibanez shielded cavity.
thanks for looking
RGFREAK is offline
post #2 of 2 (permalink) Old 09-15-2011, 08:37 PM
Reviews: 120
Re: YJM pot lug grounding ideas/suggestions
I have an EVH one which is essentially the same. I used a insulated wire (normally do this) and its fine.
LonePhantom is offline
Grounding problem? John R Pickups & wiring 0 10-06-2009 08:08 PM
When is grounding necessary? bhuether Pickups & wiring 6 02-21-2009 02:40 AM
Grounding Wire superhairycamel Pickups & wiring 2 09-22-2005 12:05 PM
Good Delay - Got any suggestions...suggestions...suggestions VaiGuy Gear, Equipment, Recording & Off Topic 16 01-09-2002 01:46 AM
New Amp Suggestions - Any Ideas? Opeth Gear, Equipment, Recording & Off Topic 12 01-04-2002 05:56 AM
