zr bridge help - Jemsite
post #1 of 6 (permalink) Old 12-02-2017, 06:27 PM Thread Starter
Unhappy zr bridge help
I'm new to both ibanez and double locking trems. I need to replace the bridge studs but i am clueless as to how to properly remove the zr bridge and existing studs. I could'nt find anything here about it. Could anyone please help me out or at least direct me to a detailed instruction. Id really appreciate it!
65mustang is offline
post #2 of 6 (permalink) Old 12-02-2017, 10:39 PM
Re: zr bridge help
Detune the E, B, and G a bit and lock the nut. Once you pull the springs off the bridge should come forward enough to have slack strings. Then just pull the nuts off the tops of the studs and the bridge should pull straight up and off.
Rich is offline
post #3 of 6 (permalink) Old 12-02-2017, 11:09 PM Thread Starter
Re: zr bridge help
Thanks Rich! I figured id change strings while im at it though. How would you recommend i incorporate this fix while changing strings? Also, are there any nono's i should be aware of before proceeding?
post #4 of 6 (permalink) Old 12-02-2017, 11:24 PM
Re: zr bridge help
All strings off will probably be even easier.
Rich is offline
post #5 of 6 (permalink) Old 12-03-2017, 12:56 AM Thread Starter
Re: zr bridge help
cool, one last question. when removing the springs is it safer to unscrew them at the block or pull the loops off from the sides of the little bar thingie. im having trouble pulling them off the sides.
post #6 of 6 (permalink) Old 12-03-2017, 01:11 AM
Re: zr bridge help
Yah, pull the screws.
Rich is offline
bridge , double locking tremolo , zero resistance , zero resistance trem , zr trem
Floyd Upgrades BRIDGE! Adam Reiver made a bridge! pics inside dakotaplaysguitar Tech: Setup, Repairs and Mods 51 09-26-2010 08:58 PM
Just installed bridge humbucker... now middle/bridge sounds funny Bun-Bun Pickups & wiring 0 02-26-2010 02:40 AM
WTB: Kahler 7330 Bridge or Gotoh 510 Wraparound Bridge X2N2 Classified Ads: Guitars and Gear 0 07-24-2009 08:41 PM
Just finished wiring and my bridge pup sounds like a blend of bridge and neck GuitarEvan07 Pickups & wiring 6 06-24-2009 12:15 AM
hard choise: Blaze Neck in bridge vs. Blaze Bridge in bridge... MF_Kitten Pickups & wiring 13 04-23-2007 11:33 AM
