ZR2 Question - Jemsite
post #1 of 1 (permalink) Old 07-11-2011, 05:37 PM Thread Starter
ZR2 Question
Hi Guys, got a stripped S420 cheaply a while ago and have been building it up, I noticed the trem has a lot of movement back and forth and side to side, like the bolts which screw into the body are too small, is this normal? when its under spring and string tension it seems ok, I have no bar to test it properly with tho'...
The previous owner had butchered the poor thing installing EMGs and adding holes for an LED and switch to the body, which I will fill and re-finish eventually... just keen to build it up and play with it, thankfully the neck is in great condition so at worse I'll get another body and trem
jeremyb is offline
zr2 problems
Strange Amp Question (possibly lame amp question) fixedaxis Gear, Equipment, Recording & Off Topic 0 09-24-2010 12:24 PM
f-space question, and pickup combination question Jing Tech: Setup, Repairs and Mods 14 05-03-2006 02:50 PM
777DY wiring question(parallel/series) +volume question mko Pickups & wiring 0 11-16-2004 07:06 AM
Question about ebay auction Question Miata1476 Vendors, Auction & Reseller Talk 6 11-12-2004 02:41 PM
BSB Question - neck finish question j i m Ibanez JEM, UV, JS & Other Signature Models 7 02-23-2001 05:29 PM
