What about a reversed ZPS? - Jemsite
Comments to Ibanez Here is your chance to post your comments to Ibanez. Officially this topic is NOT endorsed, approved or monitored by Ibanez/Hoshino. That said, voice your opinion anyway. Please be courteous.
post #1 of 7 (permalink) Old 02-21-2011, 08:03 AM Thread Starter
since the most Edge trems have a common problem, which is the tuning going sharp after pull-ups, what about a reversed ZPS to help the trem returning to zero? as it works now, it just helps the trem going back to zero after divebombs only (which usually isn't a problem on Edge trems), but not after pull-ups. or am i crazy?
nuno is offline
post #2 of 7 (permalink) Old 02-22-2011, 02:35 AM
Re: What about a reversed ZPS?
I suspect it would reverse the problem, to be honest - making the problem sag the other way moreso.
Seems as though there must be too much 'range' to the 'zero' state.
Maybe it's something to do with the felt (is it felt in there?) or whatever the bumper material is, causing some variance/buffering some movement...
That's what I would target first; see if that 'range' of zero could be reduced to ... zero =]
steve is offline
post #3 of 7 (permalink) Old 02-22-2011, 03:58 AM Thread Starter
i think a well designed device would not reverse the problem. frankly, i never had a problem with the ZPS, i don't get all this fuss about it. if it's well setup, it works, even if it's not so necessary. the real problem with the Edge family is the pull-up causing sharp tuning return. probably a kind of an ESP Arming Adjuster, which you can fine tune to keep the trem block to zero, don't know.
but then, why not a better designed set of posts? this would cut any problems directly at the source, i think.
nuno is offline
post #4 of 7 (permalink) Old 02-22-2011, 05:55 AM
Reviews: 4
They need to bring back the back stop.Those kind of stabilizers work great.Maybe they should combine the zps with the back stop.
guitarnub3 is offline
post #5 of 7 (permalink) Old 02-22-2011, 07:53 AM Thread Starter
stay on Earth, guys!
they could just make stainless steel posts with the right cut grooves first, to avoid any "problem-solving" device then.
nuno is offline
post #6 of 7 (permalink) Old 02-22-2011, 02:37 PM
Reviews: 4
maybe they could have strat trems with graphtech parts and locking tuners! hahahhahahahhahahah
fwd0120 is offline
post #7 of 7 (permalink) Old 02-23-2011, 10:19 AM
That would work perfectly fine if the trems were wilkinsons. My wilky equipped guitars don't even have locking tuners and return to pitch perfectly even with heavy use.
GuitarBizarre is offline
edge zero issue , zero point system , zps
Reversed pickups + reversed volume pot, RG550 Devon8822 Pickups & wiring 3 03-07-2010 08:30 PM
Paf joe....reversed or not? zithon Pickups & wiring 4 12-03-2009 01:40 AM
Why a reversed headstock? StTan Ibanez JEM, UV, JS & Other Signature Models 29 01-25-2006 03:54 PM
RG with reversed headstock? cy_berg All Other Guitars (including Prestige) 28 10-13-2005 12:07 PM
rg 770 reversed? pimVAI All Other Guitars (including Prestige) 5 02-01-2003 12:05 PM
