building the church help - Jemsite
post #1 of 3 (permalink) Old 07-25-2006, 07:45 AM Thread Starter
hey all, am currently learning the tapping part to building the church and am having some trouble.
the intro is ok as i can use my left palm to mute excess noise but im getting alot of string buzzing which i cant think of how to mute, the left hand is to busy moving around (in the solo section tapping) to even attempt to mute, and the right hand is busy and also cant mute, so how the hell do you get rid of the string excess noise and get it to sound cleaner?, i would have thought muting the strings at the headstock end with a cloth would work, and it does, but i know that he doesnt use one. i tried rolling off the volume on the guitar to get rid of some but its still not good enough. i was thinking that pehaps steve uses a gate (supresses any noise lower than a certain decibel level) and im sure this also work, but not sure is uses this method.
anyone solved this problem or know how to mute the strings when both hands are moving across the neck?
any help would...help
dan
dannypuk is offline
post #2 of 3 (permalink) Old 07-25-2006, 08:58 AM
Re: building the church help
I had this problem.
I just practiced until my fingers could hammer the notes harder, so they would be louder than the noise.
I also tried muting in various ways (LH and RH) and that helped, so does using the neck pickup, and less gain.
I have a problem shifting the left hand in the solo bit, though, it makes string noise (just during the bits where your right hand stays where it is) , and I can't figure a way around it.....help me, too!
Pleuvra is offline
post #3 of 3 (permalink) Old 07-30-2006, 11:15 AM Thread Starter
ok man, for those interested ive figured out how its done
Ok its quite subtle but it IS the left hand that mutes the strings to get rid of the unwanted noise, its quite difficult to do and makes it more difficult to tap with the left hand but it works.
Place the left hand with the left side of the palm muting most of the stings (about 6th-3rd/2nd), it does not mute all the strings as this completly screws up the flexibility but it dampens most of the strings that cause the terrible noise, the 3rd finger on the left hand rests on the side of the neck (side facing floor) and the little finger rests just behind that, the thumb is used to support the rest of that hand.
With this position it mutes virtually all of the strings and sound so much cleaner, its a little more difficult at first but practicing the motions and keeping a strict hand position pays off big time. the final hardest is the movment during the solo section, and it is difficult but as long as you practice slow the position changes, and importantly the hand position during the changes, making sure the left hand is in the position i described. all unwanted noise is reduced
good luck man as its a corker when it gets flowing cleanly.
once the hand position is sorted and its clean slow, its just a case of practicing it again and again
dan
dannypuk is offline
neck pickup , palm muting
Building a JEM RPG by RafaPG rafapg Ibanez JEM, UV, JS & Other Signature Models 88 01-13-2014 05:48 PM
Building the church tone... themaidenmaniac Gear, Equipment, Recording & Off Topic 12 08-04-2006 06:29 PM
Church Music??? l8r g8r Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 13 06-15-2006 01:11 AM
Building The Church: Breeds or Evos? Uthark Pickups & wiring 7 11-25-2005 11:29 PM
Question on building guitar body latinjem7vwh Tech: Setup, Repairs and Mods 1 04-10-2004 08:23 PM
