Ghost note - Jemsite
post #1 of 8 (permalink) Old 01-12-2003, 01:30 PM Thread Starter
Ghost note
What is it?
MichaelQ is offline
post #2 of 8 (permalink) Old 01-14-2003, 12:39 AM
Isn't a ghostnote an implied note?
In other words, it isn't actually played, but you can still almost "hear" it.....?
RAI6 is offline
post #3 of 8 (permalink) Old 01-14-2003, 05:43 AM
A note thats so brief it doesn't fit into traditional subdivisions of music. in a piece of 60bpm, it would equate to something like a semidemihemiquaver.
Globbits is offline
post #4 of 8 (permalink) Old 01-14-2003, 09:30 PM
is that the same thing as a grace note?
Reaper is offline
post #5 of 8 (permalink) Old 01-14-2003, 11:38 PM
I was thinking about this, and came to this conclusion:
A ghost note is a transcribers attempt to capture that certain "feeling" a musician has through musical notation.
Jeff is offline
post #6 of 8 (permalink) Old 01-15-2003, 12:22 AM
A true Ghost note, as taught to me, is a note that isn't actually picked, but is audible, but tends to be very subtle in nature and not... say hammered on hard so you can hear it as loud as if you had picked it.
BrianH is offline
post #7 of 8 (permalink) Old 01-15-2003, 10:36 AM
yeah, more or less a grace note
Globbits is offline
post #8 of 8 (permalink) Old 01-21-2003, 04:04 PM
A ghost note and grace note are not the same thing at all.
A grace note is a very quick note leading into another note, played quickly enough in a way that it doesn't interrupt the rhythm enough to require an actual time value. It can be slowed down enough to the point where it could be a normal note, but that's up to the performer. It can be a slide, hammer, pulloff to the next note, or even both notes picked. It's normally notated as a small 8th note with a little line running through the tail.
A ghost note can have any time value, occupies that exact value (unlike the grace note which doesn't take up an 8th note or anything like that), and is written in parentheses. It's used for a number of purposes, but the general idea is the note is very quiet compared to the other ones. Strumming chords (rhythm slashes) on an acoustic with some soft unaccented notes, on maybe just a couple strings of the chord, an extra note you can hear slightly in a repeat of a phrase that doesn't normally contain the note, open strings ringing sympathetically, soft hits on the snare drum in between the main beats-- all possible uses for a ghost note.
So, grace note = fully audible note, short time; ghost note: barely audible note, can have any duration.
Jordan
bakerman is offline
note sounds :dead: Slight buzz only on the Low E string "C" note nighttraveler Tech: Setup, Repairs and Mods 1 06-11-2009 11:10 PM
Reading the note Veasna7 Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 4 07-27-2007 08:16 PM
Bad note!!! - bad note on JEM90 BenC Tech: Setup, Repairs and Mods 2 01-24-2002 05:15 PM
Note on 5th doesn't sound like the same note on 17th. - Why? ElhazGuy Tech: Setup, Repairs and Mods 16 01-16-2002 03:08 AM
