help...good guitarists please read this - Jemsite
post #1 of 22 (permalink) Old 02-11-2003, 05:15 PM Thread Starter
ok the other day i saw a guy play something very heavy metally. it sounded like he was tapping but he was using the pick normally. it had something to do with the first two strings. what is it and how do execute it???? he didnt teach me how to do it
he did teach me something. something really cool. he perfomed a bend like. on the third string. at the seventh fret upwards. then with his right hand's index finger he harmonicked that same string arouynd the 17th fretit sounded like the note went falt or something. ...i hope i explaiend it clearly.
but for now please help on the first question....anyone?????
Sid Vai is offline
post #2 of 22 (permalink) Old 02-11-2003, 05:28 PM
EKG
Your first question, I am not quite understanding...
The second part...EVH does a lot of...check out his solo stuff on VH videos. Basically, "bridging" the string at a specified fret then tapping harmonics ;-)
EKG is offline
post #3 of 22 (permalink) Old 02-11-2003, 05:52 PM
He was probably using the open string as a pedal point and alternating it in with what he was fretting, sorta sounds like tapping.
Rich is offline
post #4 of 22 (permalink) Old 02-11-2003, 10:13 PM Thread Starter
ok i dont know how to describe it...if i knew i owuld just do it on my guitar.
ok, he was picking the strings. he uses the first two strings and it sounds like a lot of pull off and alternating the ring finger from second string to first string. it sounds like tapping and i want to know how to do this...please help...anything that sounds similar will do.
Sid Vai is offline
post #5 of 22 (permalink) Old 02-11-2003, 10:22 PM
Oh, 2 different strings. That's another Satchism. It still involves the open strings and now you're just fretting one fret per string. "Sweep" [if you can call it that] your pick across the 2 open strings then in the same tempo hammer on the 2 notes [one at a time of course, not together], repeat
Rich is offline
post #6 of 22 (permalink) Old 02-11-2003, 10:26 PM
You can sweep in either direction and hammer on in the same or opposite direction, plenty of variety here.
Rich is offline
post #7 of 22 (permalink) Old 02-11-2003, 10:27 PM
is he possibly talking about trilling the string with the edge of a pick? Satch does that alot too. Kinda sounds like tapping(although hyper speed).
BrianH is offline
post #8 of 22 (permalink) Old 02-11-2003, 11:28 PM Thread Starter
yes it sounds like tapping but he does it with the pick, like normal playing. it should sound like tapping
Sid Vai is offline
post #9 of 22 (permalink) Old 02-12-2003, 04:59 PM
I was looking at somthing the other day and someon mentioned you could finger tap with a pick instead of the tapping finger. Is that how you mean? ie normall tapping, but instead of tapping the fret with you finger use a pick. Ive tried but cant seem to get this affect right...how is it done correctly?
Swirly is offline
post #10 of 22 (permalink) Old 02-12-2003, 05:42 PM Thread Starter
no, hes playing normally, like right hand over pikcups, except it sounds like tapping. im going throug all this trouble bc the guy doesnt want to teach me how he does it
Sid Vai is offline
post #11 of 22 (permalink) Old 02-12-2003, 05:57 PM
Rich is offline
post #12 of 22 (permalink) Old 02-13-2003, 11:35 AM
I think this is what you mean:
|-----5-----------8---------5-------------------|
|--------5--0--5----5-0-5----5-0-5-etc-------|
Use hammer on's and pulloffs on the B string.
Large intervals like this may create the illusion of tapping.
Lenny is offline
post #13 of 22 (permalink) Old 02-13-2003, 02:03 PM
I think Rich is explaining something like this...
---0-----5---0------8-------
-0----5---------0------8----
This could be done alot of ways, not just with double stops. you hammer on from the open string to the fretted notes. Atleast this is what I think Rich is talking about.
BrianH is offline
post #14 of 22 (permalink) Old 02-13-2003, 02:19 PM
I suck at tabbing, but here goes
-0---7-0---7-0---7-0
--0-5---0-5---0-5---0
That's using an upsweep on the E and B strings and hamerring on the B first then E. Like I said, all kinds of combinations available here.
Rich is offline
post #15 of 22 (permalink) Old 02-13-2003, 02:25 PM
How about one where the open string doesn't match a hammer
-0---9-0---9-0---9-0
--0-7---0-7---0-7---0
Rich is offline
crystal planet , heavy metal , john petrucci , sweep picking , van halen
so i know most guitarists don't like rap but... skleung Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 4 12-06-2010 03:00 PM
Guitar Hero Video Game good to teach Guitarists? blackdiamond13 Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 27 08-27-2008 04:57 AM
Guitarists!?!?!?!? rickcard71 Polls 65 05-28-2008 10:19 PM
Any ESP guitarists? mike2558 All Other Guitars (including Prestige) 38 09-20-2005 10:57 AM
How good of guitarists are you jemsiters? Satch Boogie Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 95 09-11-2003 10:57 AM
