Help my right hand picking(fast) - Jemsite
post #1 of 17 (permalink) Old 12-05-2005, 04:08 PM Thread Starter
Question Help my right hand picking(fast)
Im trying to correct my right hand picking style and im palying fast runs like this could anyone mark on these tabs where the upstrokes and downstrokes go, bearing in mind im economy picking.
-----------------------------------------------------------12-10----|
-----------------------------------------------------10-12-------12-|
-----------------------------9-10-12-10-9----9-10-12----------------|
-----9-10-12-10-9----9-10-12--------------12------------------------|
--12--------------12------------------------------------------------|
or this one
-----------------------------------------------14h16p14------14--16--17-
---------------------13h14p13------13--14--16------------16-------------
p13------13--14--16------------16----------------------------------------
-----16-------------------------------------------------------------------
Heres also another one decending what strokes up or down remembering economy picking
7h8p7--5---------------------------------------------------------------
---------8-7-5------------------------7-------10-----------------------
---------------8-7-5-4-------------9b---8-12b----11~-------------------
-----------------------7-5-4-------------------------------------------
-----------------------------7-6--x------------------------------------
thnks alot everyone
ashton is offline
post #2 of 17 (permalink) Old 12-06-2005, 03:46 PM Thread Starter
Unhappy Re: Help my right hand picking(fast)
Anyone got Anything .......help thanks
ashton is offline
post #3 of 17 (permalink) Old 12-06-2005, 09:06 PM
...well, if those are the specific runs you want to do, it's up to you which way you want to transit the picking. Rarely do you run into a run which falls into the nice groove of upstroke to the higher string and downstroke to the lower.
If all you want to do is practice, you can find tons of stuff on the web. If you want an opinion on how to do your run, then apply the upstroke to higher string transition. It allows for a purposeful stroke and allows the basic down up down to be used.
When you can't, I always just try both , and then see which feels better. It's a personal thing. Then, you can throw some slides and legato to 'make' the down up down pattern work, but sometimes it's harder to learn and remember that live.
Good luck!
atarilovesyou is offline
post #4 of 17 (permalink) Old 12-06-2005, 10:02 PM
mi2tom's Avatar
just keep on practising ...... there's no shortcut on this matter
mi2tom is offline
post #5 of 17 (permalink) Old 12-06-2005, 11:24 PM
Yes, but practicing right is more important.
First of all this is all based on my experience so this isn't a golden rule to abide by or anything.
Anyway, I don't know how long you've been playing or how comfortable you are with picking. However, I'll say that learn alt. picking before you get to econ. picking. A lot of newer players that learn to play with the pick naturally prefer to play with econ picking, because it's...well...easier because you don't have to go inside-out or vice versa, which is hard to get use to. But most of them can't play very clean and smooth that way and many times play the next note (on a double downstroke) faster than they should. For this reason, learning how to alt. pick well first with consistent tempo, THEN putting some econ picking into your technique would work much better. This is all just my opinion, and has worked well for me.
btangel is offline
post #6 of 17 (permalink) Old 12-07-2005, 09:50 AM Thread Starter
Ive got alternate picking fine its just usually the descending licks that I find tricking Im not sure on my picking pattern I know its what you feel comfortable but could someone show me what they'd do for those tabs
ashton is offline
post #7 of 17 (permalink) Old 12-07-2005, 09:02 PM
...well, these licks have, as you've found, odd numbers of notes per string, so you can't just go up down up the whole way and use the "upstroke to a higher string" that seems to make them easier (at least for me).
I would go ahead and just alternate pick the whole thing, and perhaps get rid of some of the hammer ons....or at least, pop in a few to make the pattern work.
But, then you're not playing the notes you wanted to...so perhaps it's best to just figure out what notes you 'really' want to sing out, and make sure you land on those with a downstroke...other than that, these are tricky no matter what.
You might also want to see if you can play them in a different position to see if it's easier that way.
Good luck.
post #8 of 17 (permalink) Old 12-09-2005, 12:19 PM
i'd just alternate pick the whole thing, starting on a downstroke. you should be really comfortable alternate picking anything so that when you're improvising a line similar to the one you posted, you're not thinking about what down/up stroke you should be on, you just play it! if you think about your right hand too much, you're not thinking about music.
vette6600 is offline
post #9 of 17 (permalink) Old 12-09-2005, 12:50 PM
I'd like to get to the point where I can transit strings and not think about pick direction...but that often means you don't cross to a higher string in the most efficient manner, especially while improvising....if it did, then you'd be a great player indeed. If I'm learning something, or writing out what I'm doing first then I'll find the best way to do it, with some fun alternates...but in nailing the Yngwie stuff, I get methodical.
Alot of times I find myself going against the theme of upstroke to a higher string, but it almost always sounds better when I use it.
post #10 of 17 (permalink) Old 12-09-2005, 03:36 PM Thread Starter
Yeah its mainly the descendiny licks that I have trouble with its the skipping to the next string is it down or up. Maybe I should work at it more but I ve tried and Its difficult moving up a string with and upstroke without hitting the bottom string again is their such thing as economy picking descending-if so how?Thanks..
ashton is offline
post #11 of 17 (permalink) Old 12-10-2005, 10:49 AM
I used to have the same 'problem'...what eventually develops is your hand, fingers kinda 'pickup the pick' so as not to brush the higher string before you upstroke it...kinda hard to explain, but I can assure you that if I managed to get around that with lots of practice, so should you.
I first learned a bastard version of alternate picking (turned out it was more like a sweep to the next string, which is useful but you need to learn alternate first I think) and it took a good couple months to 'relearn'...I forget the term of my original style, there is a name for it....you basically continue the direction from the last string and alternate the pick notes that are on one string...
...as I've been learning lately, all that's required is time in!...and metronome!...and patience!...and a great guitar!...and cool leather pants!
post #12 of 17 (permalink) Old 12-10-2005, 02:20 PM
Just practice alternate picking up starting with a downstroke, then an upstroke.
That's how i'd do it :S
Chud is offline
post #13 of 17 (permalink) Old 12-11-2005, 03:49 AM
if you have trouble with that, you should try the 4 note per string chromatic excercises starting on a upstroke instead. try this idea with anything you normally play. turn it inside out.
post #14 of 17 (permalink) Old 12-11-2005, 08:15 AM
Here's something for you to work on. This excercise is quite tough, because you have to synchronize your string skipping with this awkward left hand fingering. This should take care of hitting other strings when string skipping
----------4--1----------------5--2-------
-------3-------2-----------4-------3-----
-----2-----------3-------3-----------4---
--1----------------4--2----------------5-
etc. Try playing down-up-down-up and then up-down-up-down.
This is from John Petrucci's Rock Discipline instructional video. GET IT!
Proview is offline
post #15 of 17 (permalink) Old 12-11-2005, 02:16 PM
to think that you're not going to credit john petrucci with that excercise( "rock discipline" dvd)
alternate picking , john petrucci , string skipping
How do you hold your picking hand? ironfistx Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 17 06-16-2012 01:37 AM
Right hand picking position mindwalker All Other Guitars (including Prestige) 17 04-23-2011 04:27 PM
picking hand/arm position problem while alternate picking oordeel Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 8 05-06-2008 07:50 PM
Another picking hand problem Penguin Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 3 09-12-2006 07:57 PM
Question on fast picking Doug Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 9 07-17-2004 06:34 AM
