Joe Satriani's squeally thing... - How? - Jemsite
post #1 of 7 (permalink) Old 03-26-2002, 10:14 AM Thread Starter
Right, I think Joe Satriani uses this quite often - think Extremist. It's where he uses his left hand under the neck for the whammy bar and picks (?) with his left hand? I have no idea what he's doing - other than the whammy bit - and have given up watching the DVD in slow-mo.
Ideas would be gratefully received.
Thanks a lot
Nick
foureyezonme is offline
post #2 of 7 (permalink) Old 03-26-2002, 03:39 PM
Reviews: 5
choke up on the pick with your thumb and hit an open harmonic over the pickups on the G string. *Do this with the bar depressed and then pull up. *It will squeal. *If you want to add a satch touch, use your whammy pedal and bring it up an octave when you pull up.
jem7vwh is offline
post #3 of 7 (permalink) Old 03-26-2002, 07:52 PM
another variation satch uses a lot is to pinch across multiple strings at once.
you need to be pretty handy with pinch harmonics in the first place, and have a fair amount of gain on to get this to work right, but it's great when you do.
reach over with the fretting hand and dump the bar down (not all the way), then do a pinch harmonic on the g-string but do it real quick and go over the b-string too, then raise the bar with the fretting hand.
if you get it right and both squeals ring out, the different tensions in the strings will make the two notes rise at different rates so you get a cool "phasing" kind of effect between them.
whammy = fun!
--cilve.
earthman is offline
post #4 of 7 (permalink) Old 03-27-2002, 09:22 AM Thread Starter
Thanks guys.
Time for me to go blind...
post #5 of 7 (permalink) Old 05-15-2002, 07:19 PM
Reviews: 3
I was kinda wondering about that technique too after watching the g3 video...
texshred777 is offline
post #6 of 7 (permalink) Old 05-15-2002, 07:57 PM
EKG
I get similar effects by pressing the trem down and striking the G and B strings, both with my right hand, and getting the harmonics with my left (fretting) hand around the first and second frets. Learned this technique watching EVH a lot
EKG is offline
post #7 of 7 (permalink) Old 06-21-2002, 12:03 AM
OME
Reviews: 6
I like playing a natural harmonic on the G-string at the 17th fret and pulling up on the bar. Also when doing a Satch harmonic cross-over
I'll make the harmonics by palming them instead of pinching them,
that way I have more control over which strings are being heard.
OME is offline
joe satriani , pinch harmonics , whammy pedal
Satriani contest (GC, whooznxt, "Master Satriani") lastsnare Off-topic / Miscellaneous 13 08-25-2012 12:42 AM
what is Satriani's amp block thing hamand Gear, Equipment, Recording & Off Topic 12 04-07-2004 09:02 PM
Intro to Joe Satriani - Love Thing eg Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 1 09-08-2003 04:15 PM
Joe Satriani tabs to Love Thing :) TrueFaith Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 4 12-09-2002 08:40 PM
Soldano rackmount amp thing... - what is this thing? texshred777 Gear, Equipment, Recording & Off Topic 3 03-27-2002 06:20 PM
