Loosen Up! - Help! - Jemsite
post #1 of 10 (permalink) Old 08-13-2001, 12:38 PM Thread Starter
Loosen Up! - Help!
I find I fret to hard, so that I'm pushing down on the strings, I'm pushing WAY too hard, making vibrato, bends, and slides harder. *Any suggestions on how I can get out of the habit? *I think it started from playing my acoustic, before I got my electric, which requires me to push harder, or it won't fret (it's really crappy). *
Two hands31 is offline
post #2 of 10 (permalink) Old 08-13-2001, 01:52 PM
Loosen Up!
My first suggestion would be get lighter gauge strings....because then, if you fret too hard, you're gonna break em....once you start running out of money for strings, you'll change your habits...;-).....no, but really, step your gauges down step by step....get strings of comparable gauge to the ones on your acoustic, once you get used to those, step down, etc, etc, until you get comfortable with a gauge. *And if you want to break the habit, spend 5-10 minutes per day paying attention to how you are playing, but only play "jazz style"....no wild bends or vibrato, just straight, accurate picking and fretting....just my two cents
Abe
P.S. *I feel your pain....before I was a lead guitar player, I was a classical bass player....LOL....I went through a LOT of strings
trouble311 is offline
post #3 of 10 (permalink) Old 08-13-2001, 04:56 PM
Loosen Up!
spend 20 mins a day playing so lightly that all you get is a dull thud when you pick a note playing a simple scale.
work up the pressure in the smallest of bits until the note start to fret and note which fingers are pushing harder than the others, If they all sound straight away, loosen off and start again. your aiming for absolute minimal effort, after about a week it will be second nature.
Devo is offline
post #4 of 10 (permalink) Old 08-13-2001, 08:19 PM Thread Starter
Loosen Up!
Thanks guys! *I'll try those suggestions!
post #5 of 10 (permalink) Old 08-14-2001, 01:46 AM
Loosen Up!
That's why I hate bad acoustics with high action. *People always say, "High action sounds better," or, "Playing a $20 acoustic all these years has made me a great player on electric." *Well, I tend to disagree. *I think I am playing my best when the notes fret real buttery and I'm just barely fretting the strings. *Imagine tickling a baby or typing on a typewriter made out of fragile glass. *I think my touch would be slightly below moderate pressure.
Josh Blagg is offline
post #6 of 10 (permalink) Old 08-17-2001, 06:32 AM
Loosen Up!
I have the same problem of fretting too hard, it also makes your hands wear out faster as well! I find that while playing if i concentrate on making the movements smaller and conciously try to touch lighter that it actually gets better, but it's something i am having to learn...
I think my problem stems from learning on an acoustic with bad action and having to press down hard! Something I have never quite got rid of, but am slowly learning to!
7 Dying Trees is offline
post #7 of 10 (permalink) Old 08-17-2001, 10:40 AM
Loosen Up!
Hah, I know what you're saying. *I also learned to play on a steel-string acoustic with HUGE strings... *for about 5 years.
I think I can bend steel bars with my fingers now, but I can't play lightly at all... the moment I "get into it", I start pushing those strings down like no tomorrow. *I have to use .10s just to keep from going broke!
MadKeithV is offline
post #8 of 10 (permalink) Old 08-17-2001, 01:31 PM
Loosen Up!
:glare:...hmm...
These sound like good suggestions, and ones that will work, no less....but wouldn't they be boring? *You'd better have a whole bunch of patience for these!
Then again, I don't really have any suggestions myself, so I dunno...:idunno:
J ackson is offline
post #9 of 10 (permalink) Old 08-17-2001, 04:38 PM
Loosen Up!
practice with your thumb not touching the back of the neck, that will force you to use a light touch ------ keep the thumb in position, but remove it from the back of the neck
shawn is offline
post #10 of 10 (permalink) Old 08-30-2001, 12:54 AM
Loosen Up!
I wouldn't know what technical suggestions to give. I think mostly it'll just take time.
Practice on 9's or 10's or whatever guage you like on electric and eventually it'll get better.
YngVaiTriani is offline
gauge strings , string acoustic
Loosen up volume and tone pots wildchild247 Tech: Setup, Repairs and Mods 6 01-07-2008 12:05 PM
Set screw won't loosen davester1234 Tech: Setup, Repairs and Mods 11 08-19-2005 10:07 AM
Any way to loosen up a tight volume pot? john1880 Tech: Setup, Repairs and Mods 11 10-25-2004 01:26 AM
help with truss rod: trying to loosen, but the nut FALLS OFF ddk Tech: Setup, Repairs and Mods 4 05-07-2004 06:10 PM
Need cure for fine tuners that loosen stratoskier Tech: Setup, Repairs and Mods 9 10-04-2002 11:45 PM
