Pinch Harmonics - HELP!!!! - Jemsite
post #1 of 18 (permalink) Old 09-15-2001, 06:12 PM Thread Starter
I can't get these done!!!! *I get lots of problems when I try doing the pinch harmonics, or whammy bar squeals. *I just can't seem to hit that spot with my thumb. *Anyone please give me tips if you can!
JS Clone 2 is offline
post #2 of 18 (permalink) Old 09-15-2001, 06:26 PM
Pinch Harmonics
1. When i pinch a harmonic, i move my fingers closer to the tip of the pick so they touch and slightly mute the string(creating a harmonic tone) as i pick.
2. The second (also basic) way of doing it is to hold your left hand finger over a string, barely touching it, and then picking that string (followed by instantly removing that lefthand finger, so you dont mute the string ). Try 5:th, 7:th 12:th and their octaves, but it can be done on all frets, it jusst takes some more practice. while doing this your holding right over the frets(as with a slide for example), not in between them as normal.
But my guess is that you allready knew those two...
(Edited by Jay Satriani at 5:34 pm on Sep. 15, 2001)
Jay Satriani is offline
post #3 of 18 (permalink) Old 09-15-2001, 06:28 PM
Pinch Harmonics
Try choking up on your pick or changing the position you hold it. It may even be a bad form that you are using to pick... these bad habits can beging when you first start playing and just stick with you..
Otherwise, try experimenting with some different picks and mm sizes as well. also be sure to play a few different guitars and see what type of PH's you are able to produce.. Sometimes it can be some of the above techniques coupled along with a fretboard radius that is unnatural to your playing abilities....
vwall is offline
post #4 of 18 (permalink) Old 09-15-2001, 06:30 PM
Pinch Harmonics
The third way is to slightly mute the string in question with the palm of your hand after/while picking a tone. But this also takes alot of time to learn. And after years of playing it will be a natural thing. To bad i cant say it is for me yet... hehehhe
post #5 of 18 (permalink) Old 09-15-2001, 07:45 PM
Pinch Harmonics
Once you learn them, pinch harmonics are second nature, but for someone learning them, I think it is a fairly difficult thing to explain with only text.
As Scott said, try different picks. I use Fender picks, so I don't know the mm measurements, but in those terms, anything less than a "Heavy" won't cut it. I personally use "Extra Heavy" ones. As far as pick size, the smaller the better, I say, as far as overall control goes. I used to use the Fender Teardrop Jazz picks, which are tiny!
As far as hitting the 'sweet spot,' keep trying. They're always hiding, and they change with every note.
Jay, your #2 method is not actually pinch harmonics, rather it is another similar technique called harp harmonics. Check out some of Eric Johnson's stuff; he has some cool lines that alternate between that and fretted notes.
Hope it helps,
-Justin
sixstringphoenix is offline
post #6 of 18 (permalink) Old 09-15-2001, 07:51 PM
Pinch Harmonics
Guess i should have noted that i use Jim Dunlop Jazz 3 and Stubby 2.0, witch are small and thick picks...
Yes i knew about that #2, but added it because
Js Clone 2 also asked about the wammy bar squeel, witch can be done with that method..
post #7 of 18 (permalink) Old 09-15-2001, 07:53 PM
Pinch Harmonics
Oh, oops, those aren't harp harmonics, those are natural harmonics! :doh:
-Justin
post #8 of 18 (permalink) Old 09-15-2001, 07:56 PM
Pinch Harmonics
Another way of making a harmonic tone appear is to pick a tone, then tapp the octave on the same string. But dont do a normal tap, just lightly touch the string, and there will be harmonic magic.... *
post #9 of 18 (permalink) Old 09-15-2001, 07:58 PM
Pinch Harmonics
I'll add that, for that method, you have to tap over the fret lightly, not where you would tap normally.
-Justin
post #10 of 18 (permalink) Old 09-16-2001, 12:11 AM
Pinch Harmonics
It doesn't matter what kind of pick you use. *That's the biggest bullsh!t I've ever heard. *L* It depends on placement, just like your 12th fre/5th/7th/9th fret harmonics...extended beyond the fretboard and onto the theoretical fretboard, above the pickups. *Work on placement.
It depends on the pick you use...sheesh...what bs.
J ackson is offline
post #11 of 18 (permalink) Old 09-16-2001, 12:17 AM
Pinch Harmonics
I'm not going to counter rudeness with rudeness, but I will say that if you use a thinner pick, you will likely have to exert more force (i.e., a harder grip) on it. So if you've a lazy hand, get a heavy pick! :laugh:
-Justin
post #12 of 18 (permalink) Old 09-16-2001, 12:36 AM
Pinch Harmonics
who's being rude? *I'm just honest. *The pick don't matter. *Placement does.
J ackson is offline
post #13 of 18 (permalink) Old 09-16-2001, 12:39 AM
Pinch Harmonics
Even if you'd say that about pinch harmonics, would you honestly use a thin pick for anything else? :biggrin: Those things click way too much to be useful!
-Justin
post #14 of 18 (permalink) Old 09-16-2001, 09:54 AM
Pinch Harmonics
more info on this topic
:read:
http://jemsiteforum.com/board/topic....9&topic=55
eviltwin is offline
post #15 of 18 (permalink) Old 09-16-2001, 11:34 PM
Pinch Harmonics
If you can get them to squeal at least some of the time, practice them on an acoustic. *Once you get it down, go back to your electric and it will seem like cake.
ericbrowning is offline
eric johnson , fretboard radius , jim dunlop , les paul , pinch harmonics , scale lengths
Pinch Harmonics Q`s? chopstix21 Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 12 07-10-2012 03:45 PM
Pinch Harmonics tt0511 Pickups & wiring 17 08-21-2007 03:35 PM
EVO's and Pinch Harmonics guitarman13 Pickups & wiring 20 07-10-2006 05:52 PM
EVO's and Pinch Harmonics guitarman13 Ibanez JEM, UV, JS & Other Signature Models 22 06-14-2006 01:38 PM
Pinch Harmonics. Shredder87 Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 24 06-09-2006 04:42 AM
