Part of a song I need to nail spot on in a month at blazing speed. I usually just do it "pull off" style. But picked sounds better, and correct. There is just something about this that's really hard for me. Not the picking speed, or the fingering, but together......it's a train wreck. I think because it's a sextuplet?
In that case it would be triplets, sextuplets would equate to 12 notes / sec.
I actually practiced similar shapes to get my string to string transitions sharper. It is well possible your difficulties are caused by the same thing. Keep going over the first section to get the transitions down, play it in all permutations on different strings ( you might want to try them with a string skip ). gradually increase the tempo untill you are at speed. Sorry, no shortcuts..
Ok, dumb question - do you have a metronome and/or are you playing with a click track?
I too have a difficulty with counting sextuplets against a standard 4/4 but once I started putting my exercises into Guitar Pro, things got a whole lot easier.
:lol: You never fail to give me a good laugh Andy:lol:
Start with a slower tempo (whatever tempo you are currently able to play it cleanly) and just keep working it up until you finally get it played at the desired speed cleanly. I've seen Vai doing exactly the same thing on difficult passages and not long ago I worked on a difficult rhythm part that was around 120BPM playing 1/16 notes. It took sometime to get it up to speed cleanly but slow steady work paid off.
Make a clip when it starts to come togther for you
Darin, if you've got a month to polish the lick, definintely try using a metronome and start slow, then build your speed. Since you have a good technique to begin with, you'll have no trouble getting 120bpm in less time than your deadline requires. I think I might try this lick when I get home, though I can already see that I'm going have a pita time when switching strings (I've been playing for a long time but I'm can't do fast speeds to save my life).
Found it easier to play with the metronome at q=240. Not very accurate playing though. Played on B string-start. First with palm muting, then without. Then there's just some beer-shredding. (My tribute to Francesco Fareri).
Cool clip, it made me think of something, it would be mildly funny to record a passage 100% sober, then record the passage after 1-2 beers, then 1-2 more and so on until it basically can no longer be played just to hear the difference in playing after consumption of alchohol and the affects it has on playing. I've seen this done with driving with fairly humorous results. Any takers?
Should've started that earlier. Actually I've recorded many takes (Vai covers) while being quite drunk. At the time they felt like the ultimate playing. Next morning... Well... You know...
Yep, I know. I've listened to my own stuff recorded early in the night and then it gets sloppier as the night progresss and the alchohol consumption goes up
But what about when you play live in a bar? You're sober and all the audience's drunk. You play like **** but the audience thinks you're the reincarnation of Jimi or something
I discovered something by playing it slow. First, it's not triplets, it's groups of 6. And only on the first 12 notes. The last nine are triplets of some kind.
Listen to this. I played it twice. The 1st time is wrong. When you get to the end of the phrase, it's not right at the of the measure. Count along and you'll see. The 2nd time, I play the last group of 9 notes faster, taking the same space as the 6 played before (I think). Making it end on the right beat.
Related Threads
Ibanez JEM Forum
1.3M posts
69.6K members
Since 2000
