Tapping while the left hand holds a chord - Jemsite
post #1 of 1 (permalink) Old 08-12-2016, 02:17 PM Thread Starter
Smile Tapping while the left hand holds a chord
Hi! Here is Lick #1 from the new series, “The Four Seasons Guitar Licks”. This lick has been recorded with an Ibanez AT-10 guitar.
The first lick is from the song “Awake”, and you can listen to this tapping theme from 01:33 of the EP here: http://youtube.com/watch?v=iNehTMP-OHM
Here is the TAB, and I’ll tell you the details below.
In this technique, it’s all about holding a chord with your left hand, and bringing in additional notes with your right hand. The key of this theme is Bb major. Just hold the first chord, which is a Bb major triad, and then tap the 19th fret on the G string. Then release this note by pulling of with your tapping hang, and behold - the original chord tone is ringing again, still fretted by your left hand. So you basically hold the chord and don’t release it at all.
From bar 5, the new chord is a Cm9, which is a minor chord with the added 7th and the 9th of the C minor scale (Bb and D). The technique is the same - just tap the next note, indicated with a “t” sign in the TAB above, and then release it and let the original chord tone ring. That’s it - I wish you happy experimenting with this technique!
JonasTamas is offline
lesson
Left hand square heel neck on right hand body VCR All Other Guitars (including Prestige) 9 05-02-2011 08:21 PM
Two hand tapping jm1681 Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 6 02-10-2007 09:05 PM
Lesson 13: Tapping overview - right hand technique jem7vwh Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 19 01-11-2005 10:00 PM
Tapping - right hand muting .guitarcake. Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 5 03-12-2004 04:42 AM
Left-hand to right-hand coordination drills??? Type O- Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 2 10-09-2002 05:45 PM
