Tuning my guitar low B to B, six string - Jemsite
post #1 of 8 (permalink) Old 11-09-2012, 09:44 PM Thread Starter
I know there are 26"-28" inch baritone guitars but sometimes I like to detune one of my regular electric guitars to a low C to C or low B to B.
With my regular setup on my electric I have either 9-42 or 10-46 roundwounds for tuning in E. When I tune D to D I am always happier with 10-46.
But what about going really low C to C, or even B to B on a regular scaled guitar neck? I have 12-52 right not and while the intonation is there, it just seems a bit loose feeling (akin to standard six string tuning with fly away 8-38 strings).
Have any of you done this (super low tuning on standard electric guitar), and is 13-56 better for a low tuning on standard guitar? I know regular scale 7 string Ibanezes do have that extra low B and does well with intonation and feel and I suspect a set may be 9-52, or 9-56 for a seven string set.
Thoughts?
63Blazer is offline
post #2 of 8 (permalink) Old 11-09-2012, 11:16 PM
Re: Tuning my guitar low B to B, six string
Ernie Ball 10's for 7 string at 10-56. I have a RG321MH that stays in C standard with a set of 12's on it. They feel fine to me.
Saxopwn is offline
post #3 of 8 (permalink) Old 11-10-2012, 12:22 AM Thread Starter
Thanks for the reply.
I will raise the action some and redo intonation and see if I like that better. I know that 13s would probably be perfect for me to tune B to B, but I will give the 12s a shot. The action may just be too low. I don't want to shred on it so action doesn't have to be super fast.
update:
This morning I played it and I noticed there was little or no buzzing so action may stay the same but either I have to get used to the floppy feeling of the strings B to B or go with 13s. For both jazz and punk rock, I loved my 13 flatwounds. Clean of course in standard tuning or E flat to E flat, or D to D, they were taught and had a mellow tone so perfect for traditional jazz. For rock and de-tuned B to B and through 100 watt Marshalls they were great for distorted chording and had a huge tone and had just enough tension to feel like 9-42s in standard tuning so I didn't have to adjust my pick attack. I may eventually go with roundwound 13s with wound third for the B to B tuning in a standard length neck.
I thought about the RGD which can go with 9s and standard tuning, but also go with much heavier strings and do almost any down-tuned arrangement. The 26.5" inch neck feels like a guitar but adds enough tension to down-tuned settings.
63Blazer is offline
post #4 of 8 (permalink) Old 11-16-2012, 11:52 AM
I play drop B on my Jem and use flat wound 12's so going to 13's for the B tuning is what I would do. Like you I love the sound of the flats when playing down low.
Playing 12's that low is just like playing 10's in standard on my guitar, so much so that when I decided to make the switch to the low tuning and string gauge that I didn't have to reset up anything on the guitar as the string tension was so close that I never noticed.
Bow Thruster is offline
post #5 of 8 (permalink) Old 12-07-2012, 11:58 AM Thread Starter
I put on a standard set of 12s and tuned it from C# to C# and it works really well and feels a lot like 10-46 tuned E to E.
These 12s are roundwound and they work out pretty well with the Bigsby though tuning stability isn't as solid as on the 10-46 and E to E tuning. I can see where a scale at least 25.5" inches is desirable for dropped tunings over a Gibson 24.75" inch scale.
I do love the new Ibanez RGD with slightly longer 26.5" inch scale that I have seen with 10-46 for dropped D to D, and it would similarly be great for C# to C#.
63Blazer is offline
post #6 of 8 (permalink) Old 12-07-2012, 12:14 PM
I've done drop C with 11's... not sure what the problem is with 12's. Maybe check your truss rod adjustment?
Guitarchaeology is offline
post #7 of 8 (permalink) Old 12-07-2012, 12:21 PM Thread Starter
When I was B to B everything buzzed a lot more on the 4th, 5th, and 6th strings. With the extra tension of going C to C, then C# to C# solved the buzzing issue. When I increased the size of nut slot at nut, the tuning was a little more stable.
I think while tuning is OK with the Bigsby, it's still best with E to E, or even F to F tuning. The locking Grover tuners help greatly, especially on frequent string gauge changes as I have done on this guitar. The neck of the ESP/LTD Viper 301 is rock solid and usually doesn't need a truss rod adjustment unless there's a radical weather change. Slight buzzing issues don't show up on the amp. If I went back to the stop tailpiece I know I wouldn't have some tuning issues as it's never that easy with a Bigsby once you are used to Kahlers, Floyds, and Edge trems.
63Blazer is offline
post #8 of 8 (permalink) Old 12-10-2012, 05:43 PM
Reviews: 11
Get a .10-.46 set and a single .62.
Ditch the .10 and string it like normal.
As for buzzing, just give it a full setup that works for that tuning and the guitar will have normal buzz like any guitar in normal E standard.
D.M.RG7620 is offline
Tuning a 6 string to low B -- which string gauge? Dee Tech: Setup, Repairs and Mods 24 05-18-2007 07:45 AM
Troubles Tuning G string guitar_chick Gear, Equipment, Recording & Off Topic 23 05-04-2007 10:36 PM
String guage for B tuning? RobV All Other Guitars (including Prestige) 1 08-07-2005 11:21 PM
Need help setting up my 7 string from B tuning to A. BillyCorgan Tech: Setup, Repairs and Mods 1 05-14-2002 10:51 AM
Tuning Down a 7 String to A - What changes would I have to m DepecheRaven Gear, Equipment, Recording & Off Topic 2 06-25-2001 10:55 AM
