Two questions about harmonising licks/phrases/Arps - Jemsite
post #1 of 2 (permalink) Old 08-29-2003, 07:48 PM Thread Starter
I know that you can harmonise a lick or piece of music by doing things like harmonising in 3rds where you play everything a 3rd above the orginal (keeping within the notes of the scale you in yeah?). Theres obviously other ways of harmonising, like 4ths etc i just used 3rds as a simple example.
I have two questions really.
One is when you harmonise a lick is there a way in which you can just move it into a certain place and be able to say "oh look its now a 3rd higher than the original" or do you have to basically work out every note.
Also how excatly do you make a harmony from argegios.Say you were doing somthing completly arpegiated do the same rules apply to normall harmonising ?
Swirly is offline
post #2 of 2 (permalink) Old 08-29-2003, 11:00 PM
Octaves are the only interval where you can truly "harmonize". 4ths and 5ths will also work, except for the one b5 (on the 7th) and the #4 (on the 4th). The others need to be harmonized "diatonically" to avoid sounding wrong.
Arpeggios are the same way.
JESTER700 is offline
Similar Searches
Greg Howe Hot Rock Licks tab
FS: Lick Library Quick licks DVD's- Steve vai, petrucci, Killer licks. sirshredsalot Classified Ads: Guitars and Gear 3 04-07-2013 07:50 PM
Jaw breaker phrases 6fingers Off-topic / Miscellaneous 10 10-12-2011 08:19 AM
Need help with 6 string arps Magical Muffin Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 5 08-26-2009 08:55 AM
sweeping arps in D-minor matt_cater Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 5 05-26-2004 02:48 PM
Q' about sweep arps, theory side of things.... Swirly Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 13 07-07-2003 08:09 PM
