VHT GP3 Guitar ALL TUBE Preamp! - $850 USD + shipping
3 pure tube channels - clean, rhythm and lead!
Each channel with switcheable EQ, Gain Boost, FX, Bright options.
Volume, 3 band EQ, Boost pot, Gain pot, Volume on each channel.
Master volume, Master 6 band EQ and Master Tube Dynamics (this makes you sound real vintage). Each distorsion channel has 2 voicing: hi-gain, low-gain.
The clean channel is Fender-like fat clean and sparkly with without distorting at high levels unless you crank the gain your self at 10.
The rhythm channel is the best! I use this for soloing even! Can go from sweet Stones light distorsion to AC/DC to Sevendust, Staind grind in your face hi-gain ballsy distorsion. This channel has no compression and it's just ripping!
The lead channel is much like rhythm but with some added compression and a bit tad more gain and bottom-end tightness. The leads are just liquid with this channel. Can go from AC/DC to really heavy gain sound!
Fully MIDI controllable and you can switch between any channels with options on and off (EQ, Gain Boost, FX, Bright) giving you tons of sounds!
This gets you the Mesa Boogie tone and them some without the muddiness.
The preamp stays tight tight tight
There's all kinds of outputs in the back, FX loop, MIDI in, out, through, amp out, recording out, aux input, and so on.
Used lightly in the studio paired with a VHT 2/50/2 power amp that I'm also selling! This setup kills any hi-gain amp out there!
---------------------------------ALSO----------------------------------
VHT 2/50/2 power amp in MINT condition! ALL TUBE! --- $850 USD + shipping
Switcheable Class A and Class A/B amp (with a switch).
The VHT power amps are the best in the industry for their amazing tone, presence, attack and tone accuracy!
Used very little in the studio. Loaded with EL34s.
Stereo operation 50 Watts a channel. Each channel runs separately as far as impedience choice is concerned( 4, 8 and 16 ohm selectors).
Internal fans to cool it down while operating.
Each channel features Volume, Depth and Presence as well as power selector. You can run this at 25W or 50W per channel with a total of 100W if you want. That's especially sweet for studio applications!
Made in USA!
BOTH THE GP3 and the 2/50/2 were used lightly in the studio for no more than 40 hours total. Practically brand new! If you need better pictures lemme know.
The GP3 + 2/50/2 combination kills any Mesa Boogie Road King or rectifier. Sounds almost if not better than the VHT Pitbull Ultra Lead!
Pictures here
http://www.distantminds.net/vhts.jpg
Made in USA!
Pictures here
