2 heads into 1 cab ... how?! - Jemsite
post #1 of 8 (permalink) Old 02-20-2004, 10:58 AM Thread Starter
Hey whats up... I need some strategy help over here =)
Let's say i have no pedals/preamps ... and I want to A/B these 2 heads hooked up to one cab.
Straight from guitar to - Y, then A to Head1, and B to Head2. Now my problem is figuring out where the spkr out of Head1 goes, and the same for spkr out of Head 2?!
My cab is a Mesa Std... so there is 1 input for mono (8ohm) and 2 inputs for stereo (4 ohm) and lets assume these heads can be flexible in their ohm settings.
Thanks for your help!
_Tino
PoGoStIk is offline
post #2 of 8 (permalink) Old 02-20-2004, 06:41 PM
you need a high gain amp switch, like the boogie model...I'm sure other people make them as well. The problem you have is that you can't simply a/b without maintaining the resistive load on the head not being used unless you have a specific piece of gear designed to do that.
A less expensive option would be to rewire your cab to operate in stereo and plug your heads into each side, then use an a/b to send your guitar signal to the desired head. But you'd only get to use half of your cab with any one amp, but the full cab with both heads going at the same time.
Gresh is offline
post #3 of 8 (permalink) Old 02-20-2004, 10:19 PM Thread Starter
could you
possibly point to a specific model of boogie so i can see what you mean?
or maybe you can explain a little more about this adjustment if you have personally seen it etc...
Thanks,
_Tino
PoGoStIk is offline
post #4 of 8 (permalink) Old 02-21-2004, 04:24 AM
Look at Radial Eng. and the "Headbone".
CrossingStar is offline
post #5 of 8 (permalink) Old 02-21-2004, 07:01 AM
The 'E-Frog' from Palmer (???) might help you out.
Else look on Ebay for a Mesa-High-Gain-Switcher.
LennyNero is offline
post #6 of 8 (permalink) Old 02-21-2004, 10:43 AM Thread Starter
thanks
for the help
PoGoStIk is offline
post #7 of 8 (permalink) Old 02-21-2004, 10:48 AM
I got another one... introduced at the last NAMM:
http://namm.harmony-central.com/WNAM.../Headbone.html
post #8 of 8 (permalink) Old 02-28-2004, 02:18 PM
I use an Axess Head Switcher to switch between two heads and one cab. Works great for A/Bing amps to compare them and, of course, for making a couple heads into the ultimate "multichannel" amp rig.
I diggit.
drrico is offline
high gain amp
peavey heads rg_man 1993 Gear, Equipment, Recording & Off Topic 5 08-14-2010 07:16 PM
Heads up! HDS Ibanez JEM, UV, JS & Other Signature Models 17 03-14-2008 08:02 AM
Heads vs. Racks NNS Gear, Equipment, Recording & Off Topic 10 11-05-2006 11:58 AM
FS RG7620 BK in the UK - heads up dex Vendors, Auction & Reseller Talk 0 04-21-2006 09:50 AM
