5150 combo vs Legacy combo - Jemsite
post #1 of 6 (permalink) Old 01-18-2002, 07:10 PM Thread Starter
I currently use a 5150 combo with my Jem and it does sound pretty good at low volumes in the lead channel..however the distortion can get "buzzy" for lack of a better term., *and the clean channel is pretty lifeless.
I m seriously considering getting the Legacy combo, but,before I do ..has anyone out there a/b ed these two. Will I be unhappy with the saturation of the lead channel in the Legacy *since many seem to feel it lacks gain??....I play Vai type guitar music and I only need enough gain to give my *artificial harmonics that " jump in yer face" quality *and add some sustain to my single line runs.
Anyone have any experience comparing these two.
Thanks
Scott
toneseeker is offline
post #2 of 6 (permalink) Old 01-18-2002, 08:14 PM
Scott, I had a 5150 and I know what you mean. I think you'll be happier with a Legacy and maybe an overdrive pedal to push it a bit. I mean, if you want Vai's sound how can you go wrong with his amp? lol
jeff l is offline
post #3 of 6 (permalink) Old 01-18-2002, 08:16 PM
site founder 0% owner
jemsite's Avatar
I'd look for a more diverse all-tube combo amp myself
Once you purge yourself of the nightmare of the 5150 you might as well play the field a little. Look beyond the Legacy but maybe keep it as an option if all else fails :biggrin: ...glen
jemsite is offline
post #4 of 6 (permalink) Old 01-19-2002, 02:34 PM
Maybe Gregory will chime in here. He has both a 5150 combo and a Legacy combo. He nver plays the 5150 anymore. His Legacy rig has very sweet tone. He has some gadgets patched in.
bob oakman is offline
post #5 of 6 (permalink) Old 01-21-2002, 11:09 AM
Toneseeker:
I completely understand where u r coming from. *I did everything to try to clear up the 5150 combo "electric saw" sound. *I changed tubes out and found that eurotubes worked the best. *They cleaned up the sound a bit. The sine on the 5150 is very peaky ^^^^^^^^^^^^. *The sine line on the Legacy is very round. *The Carvin is not as brittle as the 5150. *I also put Eurotubes in the Carvin and they worked out very nice. *If u r looking for a nice round, warm and sustain sounding amp I would recommend the Legacy. *The Carvin does have enough gain for me, but then again I really don't use that much gain. *It is usually set at 7.5. *I would recommend using a BBE sonic Maximizer with the Legacy. *The BBE really wakes up the amp. *FYI - The clean channel on the Legacy sound very nice.
Out,
Gregory
pri0531 is offline
post #6 of 6 (permalink) Old 01-21-2002, 12:43 PM Thread Starter
thanks gregory
I did put eurotubes in my amp already ...it did clean up the buzz a little. *As far as the BBE , I used one with my 5150....I found it to be a big trade off....lost too much gain with it on..besides...I dont want my tube amp's tone affected by another solid state effect. *Anyway .thanks for the advice on the Legacy.
Scott
bbe sonic , bbe sonic maximizer , combo amp , overdrive pedal , sonic maximizer , tube amp , tube combo , tube combo amp
Any reason to get a legacy 1 combo over a legacy 3 half stack? Archlute Gear, Equipment, Recording & Off Topic 8 10-07-2013 02:11 PM
Marshall JCM 2000 DSL 401 vs mesa boogie dc5 combo vs peavey 5150 combo jrpalomo Gear, Equipment, Recording & Off Topic 4 12-10-2009 04:27 PM
WTB: Peavey 5150 2x12 Combo or head, also XXX 212 combo or head. Steve-0 Classified Ads: Guitars and Gear 1 01-22-2006 12:15 AM
FS: 5150 212 combo. speedy mcfeely Classified Ads: Guitars and Gear 3 05-23-2005 12:10 PM
Carvin Legacy combo vs head - considering a combo, *does it luther Gear, Equipment, Recording & Off Topic 3 02-12-2001 08:54 PM
