6505 boost pedal - Jemsite
post #1 of 13 (permalink) Old 07-13-2010, 05:08 PM Thread Starter
6505 boost pedal
Hi guys!
I'd like to boost my 6505 combo. I am looking for recommendations for a boost pedal. My top choices so far are Ibanez TS-9 and MXR MC-401.
Your input will be greatly appreciated.
Thanks
DR5Guy is offline
post #2 of 13 (permalink) Old 07-14-2010, 03:12 PM
Re: 6505 boost pedal
Originally Posted by DR5Guy View Post
Hi guys!
Thanks
I have had the MC401, nice pedal. The Suhr Koko boost is the best boost pedal I've owned. The mid boost side is crazy cool.
Mark
samhill is offline
post #3 of 13 (permalink) Old 07-14-2010, 03:49 PM
Reviews: 9
Boost a 6505? Have you tried turning the gain up, then using a nice EQ pedal (like the MXR?) with a lower level and EQing a crunchier sound then switching it in to get the low gain sound?
Only reason I say that is that I've tried boosting my old 6505 for laughs and it didn't take to it well. Higher gain settings on the amp sound better than boosted lower gain...
Fun111 is offline
post #4 of 13 (permalink) Old 07-15-2010, 11:00 AM
Reviews: 12
Trick is to boost the rhythm channel for tight heavy metal tones. Then use the lead channel unboosted for over the top lead work.
I suggest either a MXR GT-OD or Fulltone OCD.
Van Noord is offline
post #5 of 13 (permalink) Old 07-15-2010, 12:50 PM
Reviews: 9
I still don't understand why you'd ever need to boost a 6505?! I think we need more info...
Fun111 is offline
post #6 of 13 (permalink) Old 07-15-2010, 01:50 PM
Reviews: 12
I think you're missing the reason for using boost pedals. They aren't only used for amps that don't have enough gain.
They are also used to change the character and response of an amps gain. Many amps have boat loads of gain, like the 6505, but many players prefer the sound of the amp with it's gain set to "3" and boosted, instead of setting the gain to "8" unboosted.
Some amps also do not stay tight and focused with it's gain dial set high. An OD pedal will reign in the gain and keep it clear, tight and articulate. This is especially necessary when playing fast with alternate picking and start/stop palm muting.
post #7 of 13 (permalink) Old 07-15-2010, 02:30 PM
Reviews: 9
You don't know if I'm missing the point, this is why I'm asking for more info.
Very aware of OD/Boost pedals thanks...
Fun111 is offline
post #8 of 13 (permalink) Old 07-15-2010, 03:04 PM
Reviews: 12
Easy there.....
post #9 of 13 (permalink) Old 07-15-2010, 03:08 PM
Reviews: 9
Lol, gotta love forums.
Fun111 is offline
post #10 of 13 (permalink) Old 07-16-2010, 12:06 AM Thread Starter
Excellent point! This exactly is the reason I'd like to get a boost pedal. I am currently using MXR M-108 as a booster but it is a little noisy when used with higher volume. To my ears 6505's green channel sounds much better with gain 5-6 and about 6-10 dB boost. Much better, tighter tone. 6505 is quite bright and can sound harsh when pushed beyond gain of 6 with some pickups. However, I know tone is subjective and see no problem with people using high preamp gain, it just didn't work very well for me.
As I stated initially my dilemma is choosing between a clean boost and an overdrive.
DR5Guy is offline
post #11 of 13 (permalink) Old 07-16-2010, 07:53 PM
Reviews: 9
Friend of mine uses a BB Preamp for that, sounds awesome. Gives a nice contrast to the usual Peaveyness, and from my experience seems to mix well with most amps. By that, I mean I've tried OD/Boost pedals before that are really picky, and only really come to life with a couple of amps.
This is the kinda thing you really gotta try a load of, lol.
Fun111 is offline
post #12 of 13 (permalink) Old 07-22-2010, 03:19 AM
maxon OD !
WhiteChapel5150 is offline
post #13 of 13 (permalink) Old 07-22-2010, 12:51 PM
I have used the Wylde OD, Keeley Modded Sparkle Drive, and a Cool Cat Transparent OD. With my 6505, I tended to like the Keeley the most. I think most of the pedals people have been mentioning would sound good. They are all great pedals.
fumanii is offline
6505 , boost
Similar Searches
Boost Pedal mattguitrplaya Gear, Equipment, Recording & Off Topic 2 04-21-2010 11:49 AM
Fulltone Fat Boost Pedal??? adamcbest Gear, Equipment, Recording & Off Topic 12 08-08-2004 03:27 PM
Volume pedal for Solo boost Dan D Mahnn Gear, Equipment, Recording & Off Topic 7 06-21-2003 01:03 PM
Boost pedal recommendations? stratoskier Gear, Equipment, Recording & Off Topic 1 03-16-2003 06:40 PM
Lead Boost with an EQ pedal - What are your settings? revsharp777 Gear, Equipment, Recording & Off Topic 2 07-30-2001 01:14 PM
