Abacus midi foot controller - works with JMP-1? - Jemsite
post #1 of 8 (permalink) Old 04-19-2003, 01:20 AM Thread Starter
I've just grabbed myself a JMP-1, my first midi pre, and haven't used midi control before. It seems there're heaps of options and advice given in various threads about different controllers, but I couldn't see much about the mesa boogie Abacus. Does anyone know if it is reliable and can it be used with the JMP-1 or was it designed specifically for the Triaxis?
bryangraye is offline
post #2 of 8 (permalink) Old 04-19-2003, 03:17 AM
Yes it will work (MIDI is a standard). The Abacus is not very good though, it's a really old design and they stopped making them like ten years ago. I don't think you can program it much either, I know for sure that it can only send Program Change (no CC).
If you get it for like $50 it may be worth it just to be able to change patches on the JMP-1, but if it's more expensive you're better off getting a "real" MIDI board.
Platypus is offline
post #3 of 8 (permalink) Old 04-19-2003, 11:20 AM Thread Starter
CC - do you mean Channel Change? From the pics I've seen, there are channel select buttons on the Abacus - does this not work as it is supposed to?
post #4 of 8 (permalink) Old 04-19-2003, 11:28 AM
cc=continuous control
somata is offline
post #5 of 8 (permalink) Old 04-19-2003, 09:56 PM Thread Starter
Ok. My next question is what does 'continuos control' mean exactly in the case of rack units? I could've sworn I saw a 'midi for idiots' thread somewhere round here. I'll keep looking.
post #6 of 8 (permalink) Old 04-19-2003, 11:07 PM
Do yourself a favor, and get a DMC Ground Control or Ground Control Pro.
You will not regret it. Especially the Pro.
Gearjunky is offline
post #7 of 8 (permalink) Old 04-24-2003, 09:57 PM
Platypus is right - the Abacus is a really over-built, over-sized and under-spec'd switch for changing patches ONLY! you can't control ANYTHING else with one. A Rocktron MidiMate or Roland FC200 are built tough enough, are smaller, are programmable, and are far, far more capable in terms of what they let you control on your rig and how than the Abacus... and the Rocktron or Roland will almost certainly cost significantly less...
Jimi D is offline
post #8 of 8 (permalink) Old 04-25-2003, 06:18 AM Thread Starter
Ok. So continuos control just means you have direct control over many pieces in your rack? I don't need that kind of functionality now, but I might later, so it looks like the abacus isn't the thing.
mesa boogie
ADA MC-1 MIDI Foot Controller rgr Classified Ads: Guitars and Gear 1 04-09-2011 09:29 AM
WTB: Mesa Boogie Abacus (Triaxis foot controller) Lefty Robb Classified Ads: Guitars and Gear 1 10-18-2008 04:47 PM
MIDI Foot Controller Help daenius Gear, Equipment, Recording & Off Topic 2 08-11-2008 07:17 AM
Which Midi foot controller??! synth002 Gear, Equipment, Recording & Off Topic 9 01-18-2008 01:52 AM
Looking for a midi foot controller... Ving Gear, Equipment, Recording & Off Topic 5 12-30-2002 11:56 AM
