AC Adapter for ADA MC-1 Footswitch - Jemsite
post #1 of 3 (permalink) Old 01-21-2003, 12:00 AM Thread Starter
Well I finally found a footswitch for my MP-1, but I can't figure out what kind of adapter I need. I know it's 9V, but what size plug? Polarity? How much current? Anyone have a picture? Thanks.
steeda is offline
post #2 of 3 (permalink) Old 01-21-2003, 01:09 AM
Here is the specs for the ADA adaptor
input 117vac 60Hz
output 9vdc .5a
Pete
xxxcreaturexxx is offline
post #3 of 3 (permalink) Old 01-21-2003, 01:50 AM Thread Starter
Do you know if the center ring is negative or positive? The plug is bigger than a BOSS PSA adapter plug, I wonder what size it is. Also, I assume an 800ma max adapter would work fine yes? Thanks for the info so far.
steeda is offline
ZOOM G9.2TT 220V AC ADAPTER GODRAW Gear, Equipment, Recording & Off Topic 6 06-15-2010 09:15 PM
which adapter for DOD FX-90 finstah Gear, Equipment, Recording & Off Topic 0 07-18-2008 09:31 AM
BOSS GE-7 EQ power Adapter kelmaur Gear, Equipment, Recording & Off Topic 1 08-12-2007 12:31 AM
Can i use 12V adapter on 9V rack? sugizo_esp Gear, Equipment, Recording & Off Topic 15 04-25-2006 09:27 PM
Yamaha DG-Stomp adapter question gkelm Gear, Equipment, Recording & Off Topic 3 05-27-2002 12:20 AM
