AC adapter/power suppply question...electronics knowledge? - Jemsite
post #1 of 11 (permalink) Old 05-28-2003, 07:48 PM Thread Starter
My effects unit requires a 9V AC 1.5A power supply. Will a unit rated at 9V AC 2.1 mA be OK?
Greg
gkelm is offline
post #2 of 11 (permalink) Old 05-28-2003, 08:15 PM
site founder 0% owner
jemsite's Avatar
yes.
your pedal will simply draw 1.5ma from the supply... glen
jemsite is offline
post #3 of 11 (permalink) Old 05-28-2003, 09:53 PM Thread Starter
Thanks Glen! I thought that might be the case, but wanted to confirm.
Greg
gkelm is offline
post #4 of 11 (permalink) Old 05-29-2003, 12:06 PM
Double check your ratings, you typed: "My effects unit requires a 9V AC 1.5A power supply. Will a unit rated at 9V AC 2.1 mA be OK?"
If you have a supply of 2.1 mA and are trying to power something that requires 1.5A you are GROSSLY underpowered. If you're saying you have a 2.1 Amp supply, then your'e ok, I'm just clarifying.
Rule of thumb: Keep your rated voltages the same, never venture outside the specified voltage requirements. Current you can go over but not under. Under current will cause hum and or noise in your unit.
Bamm
bammbamm is offline
post #5 of 11 (permalink) Old 05-30-2003, 12:53 AM Thread Starter
THanks Bamm...typo. It's 2.1A. I tries this power supply and it did not work...might be bad? The effects unit does work, just not with this ps. I tried it with a 9V 1.3A and it does work, but probably not a good idea, eh?
Greg
gkelm is offline
post #6 of 11 (permalink) Old 05-30-2003, 01:42 AM
Are you sure it's AC and not DC? That's a little unusual.
microdmitry is offline
post #7 of 11 (permalink) Old 05-30-2003, 11:01 AM Thread Starter
Yes, all of the above is AC. BTW, it's a Rocktron Intellifex Online.
Greg
gkelm is offline
post #8 of 11 (permalink) Old 05-30-2003, 03:31 PM
The intellifex uses an ac adaptor to convert to DC Greg. just for the record. I've seen few systems that use ac to ac converters, digital electronics require DC power as a whole.
At any rate, you now know what you need to have to keep you running.
Bamm
bammbamm is offline
post #9 of 11 (permalink) Old 05-30-2003, 05:16 PM
Bamm
Both my modelers - Yamaha DG stomp and Behringer V-Amp have AC-AC.
JESTER700 is offline
post #10 of 11 (permalink) Old 05-30-2003, 06:13 PM
Just make sure it's the correct polarity! I always find 9v adapters, get all excited that I didn't pay $20 for it and just stole it from my phone, and then realize it won't work on anything because it's the wrong polarity. So just double check to make sure......
UVmanMike is offline
post #11 of 11 (permalink) Old 05-30-2003, 07:07 PM
Yeah, but cutting & resoldering the end on reversed is easy.
rocktron intellifex
FSOT - Digitech RP-7 with power adapter data187 Classified Ads: Guitars and Gear 2 09-04-2012 02:53 PM
BOSS GE-7 EQ power Adapter kelmaur Gear, Equipment, Recording & Off Topic 1 08-12-2007 12:31 AM
A/C Power Adapter for BOSS Pedals rs70chgrrt Gear, Equipment, Recording & Off Topic 1 07-26-2005 07:06 PM
Yamaha DG-Stomp adapter question gkelm Gear, Equipment, Recording & Off Topic 3 05-27-2002 12:20 AM
crybaby wah wah peddle power adapter - where can I find one? FORTHELOVEOFSWIRL Gear, Equipment, Recording & Off Topic 3 07-04-2001 10:30 PM
