Active Monitor Connection - Jemsite
post #1 of 2 (permalink) Old 08-17-2009, 08:40 AM Thread Starter
Question Active Monitor Connection
Hi all,
I recently acquired a Boss BR-1200CD Digital recorder and I have a set of M-Audio BX5a active monitors that I'd like to connect to it. Since I'm a total friggin' noob when it comes to recording, I'm not sure what the best way is to do this.
The Boss unit has RCA outputs only and the monitors have both a balanced XLR input AND a balanced/unbalanced TRS input. Obviously, I need some kind of adapter but I'm not sure which one and where I can get it.
Can anyone offer any advice/suggestions?
Also, if anyone is familiar with the Boss BR-1200CD, how can I bypass the internal amp modeling and effects section and connect my POD X3 Live? The Boss' modeling/effects aren't bad but I prefer the X3...Again, I'd appreciate any advice!!
Thanks!!!
ButchRG is offline
post #2 of 2 (permalink) Old 08-18-2009, 08:30 AM
jb4674's Avatar
Reviews: 18
Re: Active Monitor Connection
Butch,
The way I would hook up the M-Audios to the Boss would be via the line out and I would use 1/4" Plug to RCA cables, like the ones below for example:
http://www.mogamicable.com/cab_assem...ies_patch.html
Unfortunately, these all-in-one units don't allow the user to have options when it comes to hooking up devices to them because they're an all or nothing kind of device.
I hope this helps.
Jimmy
jb4674 is offline
active monitors , boss br-1200cd , connection
Head to cab connection... sleepyone Gear, Equipment, Recording & Off Topic 4 12-21-2007 10:44 PM
HDMI Connection LethalAe86TypeR Off-topic / Miscellaneous 19 12-23-2006 06:39 PM
Seeking active (powered) studio monitor recos bduersch Gear, Equipment, Recording & Off Topic 6 07-05-2005 10:42 PM
Vai and Slash Connection?? Two hands31 Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 3 07-23-2004 08:14 AM
Neck-body connection Screaming Wind Tech: Setup, Repairs and Mods 0 02-23-2004 08:52 AM
