Added LEDs to my head - Jemsite
post #1 of 3 (permalink) Old 09-28-2012, 09:09 PM Thread Starter
I recently picked up an older V3. I have since seen that the newer models have 3 colored leds, 1 color for each channel. I thought that was rad, but I would be happy with just one color! I found a 3 foot string of LEDs on ebay for 9 bucks or so. They run on a 9v so I installed a switch between the battery and the lights( it sticks through the grate in the rear of the amp so I can turn it on and off) and here is what I ended up with:
to:
here is the switch:
GUITARMAGEDDON is offline
post #2 of 3 (permalink) Old 09-29-2012, 12:28 AM
jb4674's Avatar
Reviews: 18
Re: Added LEDs to my head
Looks cool. So what happens when you want to remove the grille in the back to replace the tubes or do any work on the amp? Will you have to remove the switch?
Jimmy
jb4674 is offline
post #3 of 3 (permalink) Old 09-29-2012, 09:19 AM Thread Starter
Jimmy
If I have to, there is just one nut holding the switch in place so no biggie. The back grill is not very big. The front one is way bigger and I can get to the tubes easily that way. Those front grills are available in different colors or in diamond plate from Carvin. I'm thinking of spraying mine with black Plasti-dip and seeing how that looks. Nice thing about that is if I get tired of it or want to go back to the original color, the Plasti-dip peels right off.
leds , v3 carvin
LEDs on RG?? shredrg All Other Guitars (including Prestige) 4 06-09-2008 09:10 AM
MADDEST LEDS I ever seen!!! Out Of This Swirled Off-topic / Miscellaneous 25 04-24-2008 06:24 PM
Aurora Project LEDs GuitarGod Tech: Setup, Repairs and Mods 6 11-12-2006 01:01 PM
RG7 with LEDs finished! Serratus All Other Guitars (including Prestige) 66 07-15-2006 08:46 PM
How much does adding LEDs affect a Jem's construction? ejmirror Ibanez JEM, UV, JS & Other Signature Models 4 03-25-2005 01:23 PM
