Advice for building a 2x12 - Jemsite
post #1 of 9 (permalink) Old 06-04-2012, 05:30 PM Thread Starter
Reviews: 3
Hey, im going to build myself a 2X12 cab with warehouse guitar speakers veteran 30's. ive decided on dimensions, but im just wondering if i should use 5/8ths inch plywood or 1/2 inch plywood. im looking to keep the weight down for portability.
IBZshredder is offline
post #2 of 9 (permalink) Old 06-04-2012, 05:45 PM
Re: Advice for building a 2x12
My advice:
1.- The wider the wood, better
2.- Don't use those speakers. I recomend you a mix: 1 WGS retro 30 & 1 WGS reaper HP You can even use a couple or WGS retro 30. those speakers rocks.
http://www.youtube.com/watch?v=_wzuFvIUOQ8
Cheers
Hating-pyramids is offline
post #3 of 9 (permalink) Old 06-05-2012, 07:54 AM
Don't knock the Veteran 30 without knowing what amp is going into it. Yeah the Retro and Reaper are nice but the Veteran can be quite good too, especially with Marshall heads in my experience.
I'd go for no less than 3/4" cabinetry grade ply myself. I'd also dovetail or finger joint the cabinet. Yes it's heavier but I have no fears of it failing either.
gideond is offline
post #4 of 9 (permalink) Old 06-19-2012, 06:29 PM
im actually in the process of cutting a 4x12 into a 2x12 for convenience running back and forth to different band practices, let me know how this goes and possbly any suggestions to help
daken1134 is offline
post #5 of 9 (permalink) Old 06-20-2012, 10:58 AM
Reviews: 6
Mesa and Avatar use marine grade, voidless 3/4-inch baltic birch. Of course this won't help with portability, but you could add removeable casters at one end of the cab and a handle at the other, and it should move around relatively easily.
Philboski is offline
post #6 of 9 (permalink) Old 06-20-2012, 11:32 AM
Reviews: 98
Here's a great site with tons of info to help you:
http://www.colomar.com/Shavano/construction.html
AlaskaBat is offline
post #7 of 9 (permalink) Old 06-20-2012, 09:25 PM
jb4674's Avatar
Reviews: 18
I agree with Phil. Using thicker wood will give you the best sound possible and those Mesa casters are awesome. The design is quite ingenious in the way that you can remove the casters without having to unscrew them and put them back the same way. You can order them directly from Mesa.
Here's a picture of what they look like:
There's a release button on the base so you can remove the caster when not needed.
This is the link to purchase them:
http://mesa.stores.yahoo.net/42tracremcas.html
Jimmy
jb4674 is offline
post #8 of 9 (permalink) Old 06-21-2012, 12:57 PM
Reviews: 6
Or you could get casters from Carvin for way less.
http://www.carvinguitars.com/products/CTS8
post #9 of 9 (permalink) Old 06-22-2012, 05:51 AM
Reviews: 11
+1 on using 3/4" material. I just finished putting a 212 cab together this week. I made the main box out of solid pine which really helps keep the weight down. It's actually very light. I would most likely us 3/4" birch ply on a 412 but pine is perfect for making a nice warm sounding 212. The baffles are all 3/8" birch ply. I didn't use plans, I just made it as small as I could to fit a pair of 12s in it. It's 13" deep so it has some bottom thump. I will probably leave it a partial open back because that best fits it's main purpose. I put a dato down the center and inserted a center baffle so it's a stereo cab. I still need to pick out and order my tolex & grill cloth. I'm not really sure what I want to cover it in yet.
I've got a pair of '74 CTS alnicos in it because it's main duty is to be used as a reamping cab for small vintage tube amp of mine that they work really well with but it's second job will be speaker cab for my low volume practice rig.
Riffraff is offline
2x12 , cab , mesa
Building a guitar: need pickup advice dmaneleven Pickups & wiring 6 09-29-2011 10:57 PM
Building custom guitar - need RAN Advice Trickae All Other Guitars (including Prestige) 4 05-06-2011 05:07 PM
Genz Benz G-Flex 2x12? Other 2x12 options? ScumTricycle Gear, Equipment, Recording & Off Topic 1 03-11-2009 11:50 PM
Seeking advice on genz-benz gflex 2x12 dontcallmepeanut Gear, Equipment, Recording & Off Topic 15 03-29-2007 07:54 PM
Building/buying rig (need advice) - starting from scratch. P wilch Gear, Equipment, Recording & Off Topic 17 08-09-2001 12:15 AM
